The tcon board or the LCD panel is faulty. Can confirm by replacing the TCON board
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "Line fault" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Probably the Tcon board problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience for TCON Board articles. http://electro-medical.blogspot.com/
Hello:
This may be due to a faulty T-Con board that needs replacing, this board is the display driver and will cause all type of symptoms when it is going bad.
HELLO
This is called "Field Collapse". Line collapse is different (a single vertical line) in the centre of the screen.
But field collapse is usually a fault in the field circuit (possibly a field output IC has gone short circuit) or electrolytic capacitors have dried out. The same can happen in a CRT TV - looks as if LCD panels are the same way! I think you will have to take this to a service centre.
GOOD LUCK! (:-)
How does the tv menue look. Does it cover the stripes or do the stripes affect the menue. if menu ok main board if menu affected bad panel. If under 1 years it is still under Samsung warr. Even if older than 1 year contact Samsung to see if they will cover repair.
