Question edited for typo 'not' to 'hot'.
Question moved from Washing Machines category.
Having the model number is useful in these questions.
According to this, a red flashing light means the water is heating. If it never goes to steady red, it may indicate that the heating element may have failed.
These sure were not out for long. The bright red button is a pressure release valve which could be faulty
hence allowing water to bypass out of the system and not having hot water. Try strapping a bag around
the pipe that goes outside and see if it fills with water. To top up
your system look on the pipes just below the boiler. There should be a
cold filling loop or a connection for one. If not get one from a plumber and ask them how to fill system up, its straight
forward enough and your problem should be fixed with this info
Where Is the Reset Button on a Rheem Hot Water Heater? On Rheem water heaters, the reset button is usually a red button located near the thermostat, at the middle of the limit switch. To access it, you will need to remove the metal panel on the unit. The red button is behind the insulation.
Have you tried draining off some back-pressure. That often is what the rapid flash means. Try pushing the hot water button then opening the steam valve. A few seconds after the pump comes on to push water out, the red light should go off. If it takes more than a few seconds, that's probably not the problem. hope this helps.
your electric water heater has one or two switches located under a panel or, panels be sure the power is off and open the panel(s) lift up the insulation and you should see a big rectangular black switch with a red button the button is a re-set switch press it then re-apply power
and, see if that fixes it if not you will have to replace the heating elements which is a difficult job
The FH means water tap closed. If you were happy with using cold only you could get a Y-piece connector and join both the red and blue inlet hose to the cold tap.
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
