Watch controls (eve mon crois)
TL= top left button
TR= top right button
BL= bottom left button
BR= bottom right button
TL= toggle light
TR= view date
BR= view alarm time
BL= toggle options
1 press --> stopwatch
2 press --> change alarm time
3 press --> change digital time
4 press --> return to regular view
(When on option)
Stopwatch:
TR= stop/start stopwatch
BR= reset stopwatch time
BL= next option
Change alarm time:
TR= +1 to selected (flashing) unit
BR= change selected (flashing) unit
BL= next option
Change digital time:
BL= next option
Normal view: (controls shown at top)
In normal view when:
TR is held down --> BR= toggle alarm on/off
TL is held down --> BL= toggle through days
BR is held down --> TR= toggle alarm on/off
(for accurate digital time go to the option of change digital time and set it to the next minute from when you are make sure that the the counting seconds are flashing. When the next minute comes press TR this will reset the seconds to '00' without changing the minute and you will now be accurate to the clock you used by less than a second)
I got this info through a long time of just experimenting with the buttons, still working on finding a way of changing the date but for now this should be enough to get you by with the watch. Hope this helps somebody :)
If the day is in a window next to the date, pull the crown out one position to the same position used for the date correction. Often turning one way changes the date, turning the other direction changes the day. If your day is on a small dial on the watch dial then pull the crown out two clicks and go around 24 hours at a time and you will see the day advance.
hi never change week or date when day is on "sun" or "mon" also never change date or week or day when time is between 9 pm and 5 am. to change day, move time back and forth between 10 pm and 2 am. moon will change only after 24 hr round (not during quick day change) hope this helps eli
