Garden Logo
James Hooper Posted on Nov 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wat hydraulic fluid do i use for my ford tractor 6700 modelEC215 serial number B364256
Bud Hayes
Level 2:
Sergeant:
  • Expert 262 Answers
  • Posted on Dec 09, 2016
Bud Hayes
Expert
Level 2:
Sergeant:
Answers
262
Questions
0
Helped
98214
Points
682
First, whatever you buy be sure it is Transmission/hydraulic fluid not just hydraulic oil. The hydraulic and trans oil are the same oil. John Deere trans fluid will work, Case IH. Tractor supply has a fluid that works good, Traveller Trans/Hydraulic Renew. It is for older tractors.
2answers
I need to know where to check and add hydraulic fluid on a 1971 ford 4000 tractor.
Had a 74 ford tractor and hydraulic reservoir was under hood in engine compartment.
What type of hydraulic fulid to use in ford 600 tractor
Get a top quality non-water based fluid and you will be OK. I looked around on the web and could not find any recommended fluid for the 600. Make sure you use real hydraulic fluid not engine oil. Hydraulic fluid has more anti-foaming and wear agents in the fluid. A real tractor shop will certainly help you with your purchase.
Dec 22, 2017 • Ford Garden
2answers
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
2answers
How to check the hydrolick fluid on a 1972 ford 5000 it has no dipstick I just got this tractor
Ford Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages4/
Helpful information and resources on Ford tractors from SSB Tractor, a leading provider of tractor ... tractor pumps oil but won't pump hydraulic fluid ..... 1972 Ford LGT165 lawn and garden tractor hydraulics ..... Ford 5000 transmission oil level
Does rear end oil and hydrodaulic fluid go in same reservoir
Ford 8n's use a commion sump, rear end, transmission and hydraulics. Ford called for 80 or 90 weight gear lube depending on temperature (winter/summer) about 5 gallons The link below is a great article on proper oil and maintenance....Hope this helps...
< http://www.myfordtractors.com/hydraulics.shtml > Ford Tractor Hydraulic System
The 3 point linkage on a ford 4000 tractor is only lifting half way and stopping with weight on it. what would be the problem?
I am not an expert nor have much experience - just a guess - low on hydraulic fluid? Check hydraulic fluid reservoir, if any, for correct level of fluid. Add correct fluid if necessary. If really low - suggests a possible leak somewhere. Should check for that as well.
Dec 06, 2011 • Garden
2helpful
2answers
I have a Ford 3500 backhoe year is mid 70's. I need to replace the transmission fluid. Any idea what tyoe of fluid?
Officially, it's listed as M2C53A trans & hydraulic oil. Hope you can track down an equivalent where you are
Top Ford Garden Experts
vince
Paul Carew
Are you a Ford Garden Expert? Answer questions, earn points and help others
