Unplug power cord from the wall outlet, then plug it back IN WHILE HOLDING DOWN THE POWER KEY = only for U.s.a and Canada
For other Countries With the power cord plugged in, turn the POWER key
OFF. Then, while holding down the ON/STANDBY
key, press POWER.
Memory back up function
Please note that the following items will be deleted from the unit's
memory if the power cord is disconnected from the AC outlet for
approximately 3 days.
• Power mode. • Distance setting.
• Input selector settings. • Input mode setting.
• Picture output. • Midnight mode setting.
• Speaker ON/OFF. • PRO LOGIC II mode setting.
• Volume level. • Broadcast band.
• BASS, TREBLE, INPUT level. • Frequency setting.
• Dimmer level. • Preset stations.
• MD/TAPE settings. • Tuning mode.
• Listen mode setting. • CINEMA EQ ON/OFF.
• Speaker settings. • LOUDNESS ON/OFF.
• SW RE-MIX ON/OFF.
Cautions
MODEL PARTS # REMOTE CONTROL # DESTINATION
VR-705-SA A70-1612-05 RC-R0626 K1P1
VR-707A A70-1617-05 RC-R0824 K2P2
VR-716A A70-1617-05 RC-R0824 K4P4
REMOTE CONTROL vs MODEL
DIFFERENT POINT
ACCESSORIES / CAUTIONS
Model Service Manual Surround Display Sub
VR-705 B51-5840-00 X09-6740-10 -
VR-705-SA - X09-6740-11 X25-6600-10
VR-707 B51-5840-00 X09-6750-12 X25-6520-12
VR-707A - X09-6750-14 X25-6610-10
VR-716 B51-5840-00 X09-6750-11 -
VR-716A - X09-6750-13 X25-6600-10
Note:
A different information will be available from this service manual. Pls refer to original service manual(B51-5840-00), too
SOURCE: Kenwood VR-207 Receiver
You will first need to check the remote control for the unit. Point the remote at a video camera and see if you see the remote light up. If it does try first to UNPLUG the unit for at least a couple of hours. If that as well does not work, you will need to have the unit serviced, as it may have a bad remote sensor on the front board or the microprocessor is No good. Depending on how old this unit is, it may not be worth repairing. Good Luck
SOURCE: Kenwood VR-715 reset?
Hello llarosa,
Yes, there is. Unplug the power cord from the wall outlet, then
plug it back in while holding down the POWER ON/STANDBY key.
That will clear the contents of the memory, reset the microcomputer and take the unit back to factory settings. Hope this helps. Let me know.
cancerags
