It is F37M
SOURCE: Deleting Old Address
This should be the correct manual for your device. I haven't taken a look at it but if for some reason it doesn't help or you can't figure it out, let me know and I will type up some detailed directions tomorrow.
http://www.navman.com/Documents/InCar/EN_default/Navman_Manual_iCN330_EN.pdf
SOURCE: Navman Satnav icn530
Did you tried to recover keys with SmartST ? The option is on the software menu
SOURCE: How do I remove old address from my Tomtom Xl
please tell me how to delete address from the tomtom system
SOURCE: Hi, I have entered my new address into my Nuvi
There are two ways to do this. If you want to delete the address from showing up in the unit when accessing the "Recently Found" locations, simply go to "Recently Found" and select "Clear" from the bottom menu. If you want to delete the saved address from the "Favorites," go to the Home Screen and select "Where to?" Then select the category where you favorite is located (may not show categories if you have none). Now select the old address from the list and select "delete," and then confirm.
SOURCE: manuel for a navman f37m
Hi
Download the manual from the link below.
www.navman.com/docs/manuals/navman-f35-f45-manual-en_gb.pdf
Hope it helps.Thanks
