SOURCE: MF Tractor 265 diesel engine fuel problems.
I ran into the same problem and found the line to the tank was clogged, take your line loose and see if your fuel flows freely if not blow some air from a compressor back up the line and into the tank. Hope this helpls
SOURCE: 1960 massey ferguson hydraulic filter location
Hello, I would say just go to a NAPA parts store and ask for a filter. If they have one they would show a part number for it. Usually the older tractors for Ford and Ferguson did not use filters or at best had metal filters that you cleaned in solvent and reused. There are Repair Manuals in soft-cover which are available at places like Tractor Supply or online.
The old tractor makers considered the transmission and differential sealed systems. This means like your new car today does not have a filter in the differential. The old tractors had manual transmissions and the filters are common in automatics.
Be careful not to overfill the trans because on old tractors the gear lube will go out the axle tubes and into the brakes. If operated on a slope, it is possible to tilt the axle tube and have the excess lube flow into the low side axle tube, ruining the brakes.
Some of the parts for the Ferguson will interchange with the N Series Ford. Ferguson had some Industry innovations that later were stolen by other makers.
SOURCE: water pump leaking into motor oil on a 451 massey ferguson
You have a blown head gasket.Don't use till its fixed keep draining out water oil and add fresh oil if you have to start tractor at all
SOURCE: What type of hydraulic oil goes in a 1954 massey ferguson farm tractor
The older tractors used type TCH which meant Torque Converter Hydraulic. That's sometimes hard to find now. NAPA has a product type TDH (stands for Torque converter, Differential, Hydraulic) and is appropriate. Regarding the pink color, some of the fluids come that way. It makes leaks easier to locate. Long live old iron!
my 135 fuel supply pump was leaking into the engine . I removed the pump pressured a line with air and found the leak at the seal
below are just a few of the tractor forum sites i use. these guys are really helpful and someone will have the answer for you. all i can say is to make sure all your levers are in the right position and check the quadrant lever position on your right.
http://forums.yesterdaystractors.com/viewforum.php?f=19&sid=419bda8adfabe7c0757a89cd5e57d483
http://www.ssbtractor.com/wwwboard/Massey_Ferguson_tractors.html
