Hello Virgil Hoppe,
Never ever try to repair these things without a anti-static wrist band...!! (below)... About $6...(
very serious).
A tiny spark you might not even feel.. is the PRIMARY REASON every semiconductor box you have EVER looked at says
No USER serviceable components inside"...
That spark can totally DESTROY almost every SEMICONDUCTOR ever made... Professional
HANDLING will always be done by
ESD (electro-
static discharge) trained personnel...
Your
POWER BOARD is most likely the problem...
(Red STBY is a really good sign: MOST LIKELY not your
MAIN-BOARD (but still... just an
educated guess)).
>> ALWAYS WEAR that
anti static wrist strap
VERIFY your replacement board
number yourself...
> TAKE LOTs of
PICTURES (and notes if necessary)
put EVERY wire & fastener
EXACTLY BACK...!!
> Force nothing: if a connection does not easily
come apart get a jewelers loupe and a bright light...
Look VERY CLOSELY for a pinch clamp or catch
lever to release...
(don't forget you will need to select a
SOURCE
on initial power-up).
You will be proud.
Sears ...
shopjimmy.com eBay, even AMAZON HAS
replacement boards... I regularly use
eBay...
(but I'm only buying
USA circuit boards)
Hope this helps.
LG 60PN6500 Power Supply EAX64880001/6 EAY62812701 #P10092 - #P10092
Shop jimmy (premier supplier (out of stock))
http://www.shopjimmy.com/lg-eay62812701-power-supply-unit.htm
lg-eay62812701-power bd, REPAIR KIT appprox $15
eBay repair & return service (postage included)
approx. $50...
Terrible price... (example only):
Amazon com 60pn6500 power
ESD (anti-static protection)
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Carnac the Magnificent
