SOURCE: Locating fuse box for cigarette lighter in 05 Chevy Malibu Classi
It is in the rear fuse block, in the trunk under the left side carpet. Good Luck
SOURCE: where is the fuse for cig. lighter for 2004 mustang
Fuse no.1(20amp) in the under dash fuse panel is for lighter.
Fuse no.9(20 amp) in the under hood fuse panel is for the power point.
SOURCE: Stuck CD in the multi CD player of 2004 Chevy Malibu Maxx
The only thing that is left for you to do is to remove the stereo and then disassemble it and remove it yourself. A little daunting but needs to be done. Sounds like it went in wrong and then became jammed
SOURCE: where is the cigarette lighter fuse box located on
The fuse for the cigarette lighter/auxillary power is located in the under hood fuse/relay block. It is a 20 amp ATM (mini) fuse. It is fuse #34 and is yellow. The location will be shown on the underside of the fuse box cover. Look along the drivers and passenger side inner fender areas for the fuse box. Charlie
SOURCE: The front cigarett lighters do not work on my 2006
I have a 2006 chevy malibu Ls and the 2 power outlets stopped working, I found the blown fuse in the trunk on the drivers side , there is a fuse box located there on mine.
