We brought it in off the curb hoping for a fridge. Is the 1 setting fridge appropriate on the lower shelves, for canned sodas, etc?We brought it in off the curb hoping for a fridge. Is the 1 setting fridge appropriate on the lower shelves, for canned sodas, etc?
You can't post conmments that contain an email address.
temperature is set by dial #1 being the warmest and 9 being the coldest the numbers on the dial are only for reference they do not reperesent a certain temperature you will need a thermometer to figure out what number is what temp but they do recommend starting in the middle
You need to replace the temperature control, (unless you find a bad wire connection to the temp control first). You can find a control that is close enough at any appliance parts store, bring the old one in for a match up. Make sure it is NOT a 39 degree constant cut in type and you will want a differential of at least 6 or 8 degrees minimum so that it wont "short cycle" which means it would run for a few minutes, shut off for a few then run again before the high side pressure comes down.
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
FIRST TURN THE TEMP CONTRAL ALL THE WAY OFF.LISTEN FOR A CLICK AND TURN TO HALF WAY SETTING IF IT CLICK IT'S ALLRIGHT, NEVER TO COLDEST,NEXT PLUG A RADIO IN THE PLUG TO MAKE SURE YOU HAVE POWER,DOES YOUR FREEZER HAVE A LIGHT ON FRONT TO TELL IF POWER IS ON?ALSO CHECK BREAKER BOX,THANKS-MIKE
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
