Question about Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz
How do I make my Samsung un46D6000sf WiFi and Bluetooth capable. It is a smart Tv with hub. Do I just Need a Samsung link stick??
  • Samsung Master
  • 4,296 Answers
Effective Way to Recover Lost Files on Samsung Galaxy
I think many users are highly proud about owning a Samsung Galaxy. But, the problem arises when they lose some crucial data from SAMSUNG Galaxy regardless of whether it happens due to accidental deletion, unintentional formatting, factory resetting without backup, Android OS update or any other reason for that matter. When files get deleted from Samsung Galaxy S9, a powerful data recovery on your Samsung Android phone is your ideal tool.
Android data recovery software is actually an amazing application for getting back and retrieve lost files from Samsung Galaxy.
Directly recover deleted or lost data from mobile phone.
Retrieve deleted files from internal memory and external SD card.
Get back photos, call logs, contacts, video files, text messages, whatsapp, etc.
Restore lost data from broken or locked Samsung device.
One-click backup and restore Samsung phone or tablet.
Support Galaxy S9/S8/S7 Edge/S7/S6 Edge/S6/S5/S4/, Galaxy Note 8/5/4/3, Galaxy J7/J5/J3/J2, Galaxy A9/A8/A7/A5/A3/ and more.
LEARN MORE
Posted on Dec 24, 2018
  • Samsung Master
  • 1,682 Answers
The TV per say does not have both Wifi or Bluetooth.
see
http://www.samsung.com/us/system/consumer/product/un/46/d6/un46d6000sfxza/7282_LED_46_6000_v10.pdf
you can get Wifi Yes, with optional LinkStick
see http://www.samsung.com/us/video/tvs/UN46D6000SFXZA-specs
Posted on Nov 12, 2016
6ya staff
SOURCE:
Network issues with Samsung Smart TV UN60JU6500FXZA
You mention two separate issues, WiFi and smart hub. As you know Samsung built in manual is the worst idea ever. There is no picture of the complete rear panel connection for example.
If the smart hub is the actual WiFi antenna then if your system doesn't recognize Smart Hub then you have a bad smart hub.
to test smart hub plug something into hub ( DVD HDMI, video game) If your remote has smart hub button press and see what appears. Otherwise select source on remote see if your attached item appears. (That would indicate smart hub does talk to TV)!
Since you can access your network when hard wired your network password is stored.
Once you have verified Smart Hub is functional then work on WiFi.
i will say my Samsung is 3 ft from my router and hard wired for better streaming speed.
I use Bluetooth access to share photos from IPads.
I would leave TV hard wired.
Sep 20, 2016 | Samsung Televison & Video
Is the samsung magic remote control compatible with the UA32F4500AK tv ??
Since they are both samsung, I would bet you money they will work together. You just have to pair them up. If your smart tv doesn't have built-in wifi or bluetooth, you need to connect a compatible adapter so that they can communicate.
the manual for your tv can be found here:
32 HD Flat Smart TV F4500 Series 4 UA32F4500AKXXA Support SAMSUNG Africa
Feb 15, 2016 | Samsung Televison & Video
Samsung UN40H5203AF smart tv..... is it blue tooth capable?
No, but it has smart hub and various other connectivity....what Bluetooth device did you want to connect?
Feb 14, 2016 | Samsung Televison & Video
I got a polaroid wireless speaker pbt 3001 will it work whis my new smart tv samsung
If your TV is bluetooth enabled, yes the same as your phone or other device.
If your TV is not bluetooth enabled, yes, but only with the auxiliary cable that came with your PBT 3001. The back of your TV should have a coaxial audio out (a solitary orange audio output). Depending on your model TV, you may have to get an adapter to be able to use this output.
http://www.southerntelecom.com/polariodsupport/downloads/PBT3001_battery.pdf
Mar 02, 2015 | Samsung Televison & Video
Can my Samsung 46" LED TV connect to the internet
If you have purchased a Samsung smart TV with Smart Hub you will be able to connect to the internet using the web browser found in the Apps when running Smart Hub function.
You will need to have either an Ethernet cable connected to your TV from your router or you can connect using WiFi is your TV is so equipped.
You need to use the menu to go to the internet connection setup.
I hope this answer is helpful to you.
Mar 01, 2015 | Samsung Televison & Video
How di I Bluetooth my phone to my Samsung smart tv.?
Turn Bluetooth on your phone and search Bluetooth devices to find your smart TV and pair with it!
Oct 18, 2014 | Televison & Video
Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Logo
535 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
