SOURCE: viper 771xv remote start problem
the led should blink a code that tells you why it shut down or failed to start
SOURCE: Remote start installation problem
If you have the Manual There May Be A "TIMER Setting for RUN time . I have Installed Some that Do Have this Feature
SOURCE: installing a remote starter\need wiring colour
JOIN THE 12VOLT FORUM FOR WIRE COLORS
WWW.THE12VOLT.COM
SOURCE: prestige remote start APS-901C
The tach wire for the 07 Yaris is light green at the data connector under the dash. If you have chosen to go to an injector or coil and, the system responds with low or no tach, go to the tach programming sequence again but, while programming the tach increase the rpm by putting your foot on the accelerator and holding the rpms at 1500 during programming.
Your other option is to program the system for voltage instead of tach. When programmed for voltage, also program for timed output instead of average.
