Question about LG RU-44SZ61D 44" TV
DLP Proj TV RU-44SZ61D - Replaced fan. Temp light blinks once when lamp starts and then lamp shuts off. Then temp light blinks once (rest) twice (rest) until the fan turns off. Any ideas?
    Top Expert:
  • LG Master
  • 76,060 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
Posted on Nov 13, 2016
SOURCE:
ryanriopel28
  • 130 Answers
SOURCE: Tv turns off. Temp light blinks 4 times
hang on, you said you returned it today? Then why are you asking?
Posted on Dec 18, 2007
  • 441 Answers
SOURCE: samasung dlp tv will not turn on
check that the lamp in put in all the way. If you do not have it in exactly right it wont work. Also make sure that the lamp cover is secured
Posted on Jan 10, 2009
  • 381 Answers
SOURCE: LG DLP TV temp problem
A temp problem? First check all the fans and make sure they are free from debris or check to see if they are spinning.
Posted on Dec 19, 2009
SOURCE: Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Posted on May 03, 2010
SOURCE: samsung dlp hln617w does not tun on
this model number do not use lamp ?????????
Posted on Jun 10, 2010
Lamp light blinks 5 times
The lamp might be at the end of its life. Change the lamp.
Dec 19, 2012 | LG RU-44SZ61D 44" TV
Samsung 50 inch DLP
Most Dlp sets have a fan for cooling the bulb this should start at switch on if it doesnt bulb will not light.
Check fan is pluged in & that blades can turn freely.
Oct 11, 2007 | Samsung (LTR268W) Television
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My samsung dlp tv intermittently just shuts off...don't know if it is because of the lamp or what
When it shuts down, do the LEDS on the front blink? There are 3 of them. Standby, temp and lamp. Do any combination of the 3 blink when shuting down. I could tell you where to start just by those lights blinking.
Dec 23, 2009 | Samsung DLP HL-P5663W 56" TV
Dec 17, 2009 | LG RU-52SZ51D 52" Rear Projection...
Samsung DLP TV time, temp and lamp lights blinking... won't turn
Les,
I'm not a TV repair guy but my owners manual states that when all three LED's or lights on the front of the TV are flashing, that the lamp needs to be replaced. Might want to look into this. Good luck!
Greg
Aug 30, 2009 | Samsung DLP HL-P5663W 56" TV
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
My DLP TV shut itself off & won't turn on, help!
The 3 lights on the tv are there to help you diagnose the problem. There should be Timer, Lamp, and Temp. If all 3 are blinking, the LED may be defective. If standby and temp are blinking, it's a problem w/the cooling fan.
Let me know if that helps.
Dec 15, 2008 | Microsoft Xbox 360 Console
Is my lamp out on my LG?
Most likely you can have 1 or 2 problems.
1! the light is busted and you will have to replace that. You might also need to check your cooler fan bearing as you indicate it makes noise.
Please open following link( you need acrobat reader)
this is the service manual for your TV
ru-44sz61d
Apr 30, 2008 | LG RU-44SZ61D 44" TV
I have a LG RU-44SZ61D DLP TV and recently replaced the bulb. After about two months the TV went really dim and then started shutting off. The problem increased to the point where you couldnt have the tv...
DLPs have flow chart trouble shooting techniques to pinpoint exactly why your set isnt completeing the boot sequence. If you would like the service manual for your model let me know and i will post a link where you can purchase a complete one.
Apr 06, 2008 | Televison & Video
LG RU-44SZ61D 44" TV Logo
49 people viewed this question
RONALD CARTER JR
