Camping, Backpacking & Hiking Logo
P
Phil Summerour Posted on Nov 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a defiant flashlight that has a flat chip type bulb. I need to get one for my flashlight
john h
Level 3:
Top Expert:
  • Camping, Bac... Master 29,494 Answers
  • Posted on Nov 12, 2016
john h
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7561237
Points
193449
Look up your model online or go to defiant site for location of distributor or replacement parts
Need manual for Defiant Armormax 3D flashlight
there isn't one. It comes in a blister pack, you put the batteries in and and turn it on.
https://www.google.com/search?q=manual+for+Defiant+Armormax+3D+flashlight
Defiant flashlight HD15Q451 disassembly and replacement switch
So if you do not sell repair parts, and are suggesting that the poster call the manufacturer...
I have one major question::::
Who manufactures Defiant LED Flashlights?
It is not Defiant Infustries, I checked.
I dropped my Defiant 1000 lumen led flashlight it broke the switch/endcap I'm trying to get a replacement its the 3 D cell one has a high/low switch
Sorry we do not sell parts, if you can get the part it would need to come from the manufacturer or distributor, really doubt that they make replacement parts.
1helpful
Defiant headlamp; where's the tab to be removed?
If you are talking about a shipping tab that prevents the batteries from discharging during shipping, look inside the battery compartment.
There should be a plastic, or cardboard tab, that prevents one of the battery ends from make contact with the flashlight. Just pull the tab to remove it.
1helpful
I need to find a ac/dc charger for a Defiant Flashlight Model 800-2701D Can you help??
This flashlight is sold by Home Depot, and it is possible that you might be able to find a name-brand exact replacement charger there. However, you almost certainly can find a replacement charger elsewhere for less money.
Looking at a picture of the light and its power adapter, it appears that the light has a standard barrel charging port. A dollar store or "Dollar Plus" store is likely to sell inexpensive multi-voltage universal chargers that will fit this light and get you back in business for under $5.
When fitting a non-OEM charger to your light, make sure that you've set proper polarity and input voltage for your device, or else you may damage it in charging. Many devices specify voltage and polarity right on the device, molded into the case or on a small sticker. That makes this process super-easy. Otherwise, you may have to head down to a Home Depot and peek at one of these lights in its box to read the voltage output off the stock charger. The odds are pretty good that it'll be putting out 12 volts, but I won't guarantee that by any means--input may be 6v or even 4.5 volts, though those are much less common in lights of this type.
How do i replace the bulb
Julio, the black bezel will unscrew from the main housing. The bulb is either a screw-in or friction fit (pushes in) type. Most hardware stores will carry a replacement bulb that works for this flashlight. Be sure to take the burned out bulb with you to match it correctly.
Hope this helps.
Top Camping, Backpacking & Hiking Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
