SOURCE: coolpix nikon digital camera
This sounds like a broken or cracked LCD screen. The backlite is working, thus you will get the white screen. The LCD could also be disconnected internally, or has other problems. But this is a direct problem with the LCD.
A camera like this can usually take pictures, and you may be able to use it to set the menus by using the video cable to the TV or computer screen (some flat screens have video inputs).
SOURCE: black monitor Nikon Coolpix S4 Digital
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
SOURCE: nikon coolpix S3- most of the screen is black on shooting mode
I had the same problem with mine. I searched the web and came across this one. My camera had a black screen but everything else worked. I read some of the comments and a few people said to hit it. I hit the camera in the side of my hand a few times and it started to work. Thanks for the info. It sound carzy but it works.
Now working Nikon coolpix
SOURCE: nikon coolpix S6 screen black
All you have to do is lay your camera with the LCD side down, make sure its on a soft surface like a carpet or a pillow. Once you have it laying down, put a peice or two of newspaper, or any paper, on top of the camera. and then hit it a few times with something. like a brush or anything hard like that. it worked for me. :) good luck.
SOURCE: How to fix my nikon coolpix S220 for free. The
hi..
I suggest you contact Nikon support and ask where is the nearest
service center so they can replace your LCD screen. you can find
contact information of Nikon support in your country athttp://imaging.nikon.com/products/imaging/worldwide/index.htm#americas
thank u
rate me!!
is there some small spot on the screen or maybe some black thing. it is due to the lcd screen liquid leaks out.so the lcd seems so blurry.
http://www.digitalcamera-parts.net/
e-mail:[email protected]
