SOURCE: upside down images
ALL telescopes will show the image upside-down. You learn to adjust for this. IF you must, they do make a lens called an "erecting lens" that would flip the image back right-side up.
SOURCE: upside down images on my telescope. Bought used -no manuel. What to do?
In a refractor images are upside down as with most telescopes. You need an image erector to create a normal correct R and L and Up and Down image. It is a lens which goes in front of the eyepiece to give a correct image.
SOURCE: everything is upside down
Astronomical telescopes produce an upside-down and reversed image (image is rotated 180 degrees from an upright position) since this doesn't matter when you are looking at things in the night sky. Accessories are available for rotating the image to an upright position, but most of those accessories do not work well with Newtonian style reflector telescopes such as the 114EQ reflector.
SOURCE: When viewing everything is upside down.
Yes, all astronomical telescopes show images upside down. There is no up or down in space.
SOURCE: my 102mm astro-nova telescope shows everthing
No, all astronomical telescopes show upside down images. You can buy what is called an "erecting prism" (just Google it) to use for terrestrial viewing.
Remember --- no up or down in space! Read my "TIPS" in my Profile, called ----"Frequently Asked Question".
Clear Skies!
Testimonial: "Thanks for the help!!"
