SOURCE: Epson Stylus cx4800 printer
On my RX680 the language setting is in the Maintenance section of the setup menu under Langue.
SOURCE: language change
Press the check button and the right arrow button in this combination:
check, arrow, check, check, check.
This should bring you back to the ready screen after a brief pause.
SOURCE: CHANGING PRINTER CONTROL PANEL LANGUAGE
See solution below:
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Thanks
SOURCE: How can I change the language on my Epson Stylus printer
my printer is using some foreighn language not english how do when i want to do my inks do i change it to english?
SOURCE: change language
Follow these steps to resolve the issue.
1. Unplug the power cord from the back of the product.
2. Press and hold the Cancel and Color Copy buttons simultaneously on the control panel.(My color button was the green button)
3. While still pressing the buttons, reconnect the power cord to the back of the product.
4. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
5. If the product automatically turns off, turn it on.
6. When prompted, select the correct language and country/region, and then press the OK button. Press the OK button again to confirm the selection.
NOTE: Some products might have a promotional sticker on the control panel display. Make sure that any stickers are removed from the control panel display before troubleshooting this issue.
If you have completed all the steps listed above and are still experiencing a problem, service the product.
These directions were copied from the following url:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368025&cc=us&lc=en&dlc=en&product=3192753&tmp_track_link=ot_search
Solution
