Question about Lanier Office Equipment & Supplies
Lanier 5613f display functional problem sc552, how can i resolve these problems
LANIER 5613F COPIER MACHINE
2 Suggested Answers
SOURCE:
SOURCE: How to replace drum unit
open right cover, and front cover. Remove toner bottle assembly (not just bottle), unplug drum (photoconductor) connector. Press the gray/silver release tab and slide out drum. Install and plug in new unit, replace toner assembly, close covers, and the new unit is automatically detected and calibration will begin.
Posted on May 26, 2009
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
Lanier copier ld425csp screen froze''
Lanier and Ricoh have been having a huge problem with their touch screens going bad. If you have a service contract on your copier, you should be able to get it replaced for free under the warranty.
In the meantime, try turning the machine off and back on, and you might be able to get it working temporarily.
Jul 12, 2010 | Lanier Office Equipment & Supplies
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
We have a code SC552 functional problem with copier what does this mean
if the machine is a plack and white ricoh then the new error code is for the thermistors in the fuser they are not sending the correct temp readings check the fuser for toner build up on the surfaces of the thermistors and check the thermo fuses to see if they are blown....GOOD LUCK aa>>
Jul 30, 2009 | Lanier Office Equipment & Supplies
Where can I find parts for my Lanier 5613F paper tray?
Hello sir; Please contact with me by email, I can get it for you.
Jul 18, 2009 | Lanier 1205 Copier
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
May 25, 2009 | Lanier Office Equipment & Supplies
The function read out has gone dark on our LANIER 2138 COPIER/PRINTER
did you turn the dial to light the display? if so the back lights are out on the display or the ballest is bad. you need to replace the diaply. have a tech come out.
May 14, 2009 | Lanier Office Equipment & Supplies
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
