Music Logo
Randy Ferron Posted on Nov 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get sound from a nady audio 4130 mpm 4 channel power mixer
rhodesworks
Level 3:
Top Expert:
  • Nady Systems Master 3,159 Answers
  • Posted on Nov 11, 2016
rhodesworks
Nady Systems Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
562030
Points
331463
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
2answers
My behringer pmp3000 doesn't seem to have much power to use my two peavey 12" speakers and use a mic. I have to push the gain and faders up more than I think I should have to, to get a decent level of...
Where do you have the gain control set on the Mic channel ?
If you have no issues with either the speakers or the Mic, and the gain control for the channel you have the Mic plugged into is set at a somewhat "normal" position, you might have a problem with the mixer itself.
No sound from my 2 year old Nady MPM 4130 pa system
Very likely source of this problem is the "mixer out/amp in" jack on the back. Anything plugged in there breaks the signal path so, obviously any off board equipment plugged in there needs to be checked...but that jack itself could be faulty or even just dirty. If there is nothing plugged into it....you can get a phone plug (power off) and plug in and remove it a few times. This is a switching type jack so if the "switch" part of it isn't connecting with nothing plugged into it, the signal path would be broken and give you the results you've been having.
How to connect it ?
Instructions
    • 1
      Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
    • 2
      Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
    • 3
      Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
    • 4
      Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
    • 5
      Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
    • Audi Performance Chip
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
1helpful
I don't have a problem. Just a question. I have a behringer pmp3000. Where is the best place to connect two mackie active speakers for maximum results.
There is no such thing as "MAXIMUM" results... Connect the speakers to the MAIN L and R jacks on the face using 1/4 inch TRS (balanced) interconnect cables. DO NOT USE TS unbalanced cables!!! Also an absolute requirement is that the connected active speakers are powered from the SAME receptacle as this mixer. Yes, this means running extension cords, but unless you can tolerate noise due to ground bounce and damage to your equipment respect this requirement... it isn't in the manuals but is well known among professional sound people. Also please read my tip in regard to a hazard for PMP mixers on Fixya tips regarding Channel A when using 1/4 inch adapters from the Speakon outputs.
The MPM4130X works for several months then decides to blow fuses. This has happened twice now, so I suspect a design flaw. If I could get a schematic, I could possibly design in a little more margin to...
If ONLY the fuse blows and replacing it restores operation I would suspect an operational problem. Possibilities... does a speaker lead get grounded? Can the microphones hear the speakers? This latter is important because a supersonic feedback could occur that you can't hear but overheats the amplifiers. DO NOT boost the highs with EQ to avoid this possibility. Always check that the speaker leads are secure before power the unit up. 1/4 inch plugs/jacks are notorious as speaker connections due to the shorting possibility. You MAY have to go through the manufacturer to get schematic.
2helpful
Mixer is introducing crackling sound intermittently to the process
Isolate one channel at a time to see if a particular channel is the problem. Make sure ALL interconnected equipment is powered from the SAME receptacle or power conditioner. A remote amplifier MUST be powered from the same source as the mixer, even if it requires a separate run to power it. Make sure all cables are BALANCED, either XLR or TRS cables. Sometimes a cable can have a broken wire or shield and cause this.
Can't get no output sound from my Behringer PMX660M mixer. All lights are on, power on is on, line-ins work correctly; speakon cables good but sound when instrument played through mixer.
The power amps may be blown... PLEASE read my tip on Fixya about the hazard with PMP mixers if you use Speakon to 1/4 inch cables. The sleeve or barrel of the Channel A plug is the hot, not the tip. Touch it to ground and goodbye Channel A of the amp.
Do this test: Plug a set of earphones into the Main out L and R jacks and see if audio comes out there. (it will only be in one side of the headphone and not too strong... If both L and R have signal there is a problem with the power amp or its configuration. Make sure the slide switch is up in the MAIN L/R position (top position) If all that is correct, the power amps have probably blown. Repair takes a lot of work and getting parts from Behringer now is really hard. The amp module is an HCA2400 and the only source seems to be FullCompass.com...
If I'am powering 2 Peavey 4 ohm bass binns, then linking, from the base bins, 2 15" 4ohm cabs, should my selector switch be in main L and R mode ,or Bridge mode for maxium output and performance,...
You CANNOT power 4 total 4 ohm speakers from this unit without special configuration. The lowest you can go is 4 ohms per side, which would be one 4 ohm cabinet per side. You would have to do a series parallel arrangement with the resources you have... two Peavey's in series and that combination in parallel with two 15's in series...
This is a VERY unsafe configuration with this mixer. ALSO please read my tip on here in regard to PMP mixer grounding hazard of the A channel when using Speakon to 1/4 inch cables.
Frankly, forget about maximum performance unless you want to risk blowing your mixer...
If I were you, I would put the two 15's in SERIES as 8 ohms on one of the channels and the Peavey's in SERIES as 8 ohms on the other channel.
You would be well to heed this warning as I have repaired a bunch of these units. Be careful of any poor speaker connections as there is an insulation breakdown problem in the power amp circuit board if a speaker becomes intermittent. If something fails DO NOT replace the pwer fuse as you will do more damage.
1helpful
What do i need in a mixer? i want to connect my kaoss pad mini, and kaossilator, and obviously a couple of cdjs, and where do i connect them straight in the mixer or amp, im awaiting my purchase and just...
For dj use, industry standard would be something like a Pioneer DJM600 mixer. 4 channels w/ effects and a mic input. To use kaoss it's best to go into Send/Return input through the effects. By tapping on Send, all sound is sent out to the kaoss pad, and comes back into the mixer into the Return inputs. By doing this you can have the kaoss pad on sitting next to the mixer ready to apply effects all the time. Then connect the master outputs from mixer into your amp, or straight to powered speakers. Kaossilator is more of an instrument than effects unit, so plug in to channel 3 after your 2 cdjs in channel 1 and 2. You still have a spare channel left. I use 2 x 1200s and 2 x cdjs with kaoss pad through effects channel in this way. A 4 channel mixer is plenty.
Top Nady Systems Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Nady Systems Music Expert? Answer questions, earn points and help others
