SOURCE: jl audio E6450 cutting out
hi, have you figured out whats wrong with ur amp ...i have the same amp ....and as soon as i finished the connections ...and connect the remote on wire,,, the amp goes on ...making a ticking sound with the green light blinking and the red light staying solid on ...whats the problem please help ....how can i fix this ......my amp is a jl e6450 ....im using a panasonic cd player with a built in amp ....and thats the cd player im trying to connect to the jl amp ...please HELP
SOURCE: Jl Audio 500/1 Car Audio
There are no fuses inside the amp.
Are any of the lights lighting up on the amp?
If so, which ones?
SOURCE: Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
SOURCE: i bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
SOURCE: 500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
