First lets get the buttons identified. Electronic 4 button watches are probably controlled by the same chip. Top left is the light button. Going clock wise S2 (Stop/Start), S1 (Reset), and S3 (Mode). Press S3 button (lower left) 3 times.- Tuesday flag and seconds should flash. Press S2 and Seconds will set to 00. Press S1 one time, Minutes flash and advance by pushing S2. Press S1 again and Hour digits Flash and S2 makes them advance. Continue through Date, Month, Day. When finished press S3
I think you must check the instruction book properly. Read the instructions carefully and if the problem still continue then take help from service center.
First look for the set button then press it ,a long press and If it is
blinking that's the time you to select the hour ,the minutes,the
day/date,the alarms and the special features of your watch.The right
button the up and down or for scrolling.Try all of this so your time
will set.
hold right side buttons . time will flash set using top button, then use lower button to move through each aspect of menu. You use the top button to make changes then bottom to go to next option. Lower left button to exit
Hope it helps
Roty:)
