Question about Sony VPL-ES7 LCD Projector
Sony VPL-ES7 projector boots up after few seconds switches off, with a red light flashing severally on the power button. Please what could be the problem because i have serviced the projector!!!!
    Habit-Forming:
    New Friend:
  • 13 Answers
Check the fan connections, one might not be connected right if you have just serviced it. Switching off with a flashing red light usually indicates a fan error.
Also is there a sequence to the flashes? e.g, 4 flashes and pause?
some manufacturers have a fault code table for the amount of flashes.
Posted on Nov 17, 2016
SOURCE:
  • 4234 Answers
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
projdoc
  • 2239 Answers
SOURCE: Sony Projector VPL-VW 10HT 2 problems 1)The
there is a lock on the projector that needs to be removed. check the manual for the code.
Posted on Aug 20, 2009
SOURCE: Sony BRAVIA VPL-AW15 LCD Projector power light
i have color bands running through the picture
Posted on Feb 13, 2010
caroldon
  • 17130 Answers
SOURCE: Sony VPL-EX3 projector on/off switch
Possible that the lamp is faulty -if the hours have elapsed- check the lamp holder, the fitments.
check also the filters, clean and reset.
Make sure the power supply Unit is not having any poor soldering or faulty components to reduce the voltage output to the lamp thus making it shut down..
Posted on Jan 17, 2011
  • 55 Answers
SOURCE: SONY VPL FX-40 projector. After plug
A Flashing Red ON/STANDBY LED means one of the following
2 Flashes - The internal temprature is high. Check the air holes are unobstructed.
4 Flashes - The fan is broken
6 Flashes - The internal electrical system has failed.
There is no entry in the manual for 12 red flashes.
Posted on Feb 19, 2011
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
Hello.. My projector came on minutes ago now the light is just blinking. Can you please help? I have a Sony vpl-es7
You might check the following:
* signal is going to the input. If not, does the menu come up?
* air flow is ok. Projectors don't run well if they are hot and can't breathe
Jun 29, 2015 | Sony VPL ES7 SVGA 800 x 600 LCD projector...
My Sony VPL ES4 switches on quite Ok, but after some seconds the bulb goes off and a red light just blinks
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
Jun 23, 2015 | Sony VPL-ES4 Projector
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
Jan 28, 2015 | Sony Bravia® VPL-AW10 Projector
Why the remote for Sony VPL-ES7 projector won't change the slides but it will turn the projector off and on?
Have you connected the USB cable to your laptop so that the Sony remote can act as a mouse? Did the laptop respond by loading drivers?
Sep 04, 2014 | Sony VPL-ES7 LCD Projector
Lamp is not working
How many times is the red light flashing at one time? The flashing is an error code, the number of flashes indicated the problem. It could be the bulb, the fan, a power issue, or even your altitude.
Mar 02, 2014 | Sony VPL-EX100 3LCD Projector VPLEX100
Projector starts the goes off by itself.
Check the fan is working could be shutting down cause overheat
Oct 16, 2012 | Sony VPL-ES7 LCD Projector
SONY VPL FX-40 projector. After plug in-ON/Standby LED is red for few seconds and starts flashes in red(repetition rate of 12 flashes). After pressing I/O key-ON/Standby LED flashes in green(few...
Feb 19, 2011 | Sony VPL-FX40 Projector
Press the power button to switch it on, the sony logo lights up and it switches on as per normal operation, it then switches off after a few seconds and the temp/fan light flashes
hi,
may be your projectors lamp colling fan have some problem. may be it is get jammed due to dust or it may be faulty. without fan the lamp will get over heated. that's why the temp/ fan lights flashes.
jus check it . need further help feel free to contact.
ok
Dec 20, 2010 | Sony Projector Lamp for VPL-HS51
Sony VPL-ES7 LCD Projector Logo
604 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
