Question about Kohler Home
What does Error 5 mean on a Kohler Steam Shower Model K13PC? How do I fix it?
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 35 Answers
SOURCE: dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Posted on Feb 01, 2009
Raypena
REYNALDO DE LA PENA
  • 41 Answers
SOURCE: Kohler Steam Shower. Getting ERROR MESSAGE 5.
check the steam outlet to make sure is properly tight this can cause a false ERR 5
ERR5 comes up when water flow to the unit is blocked or debris has gotten in the unit and clogged check filters,test the water flow
Posted on May 30, 2011
I have a steam shower cubicle and when the water is switched off it still drips from the shower head,it only stops if I run the hot water tap in the sink
Most likely the issue is the unit is not isolating the water when turned off. Inside the shower valve will be an on off valve that will likely look like thus 06a0e29a-a81e-4b1d-b746-6d8bf0394774.jpg if you can locate one of these and replace your dripping will be resolved. Alternatively if this is only dripping from the larger monsoon in the roof, this can drip for a while after use as it holds a fair bit of water.
Can also try selecting one of the other features when not in use such as he back massage jets ( if you have a 3 dial valve) if it still drips then the problem will almost certainly be a replacement on/off valve
Steam Shower Parts Spares
Jan 04, 2014 | Kohler K-1698-G Brushed Chrome Tandem...
Kohler Steam Shower. Getting ERROR MESSAGE 5. Need to know how to fix the problem.
May 30, 2011 | Kohler Home
Error 5
-error 5 is caused by the back pressure of the steam head if water supply to the generator is sufficient and the steam output pipe to the steam head is plumbed according to the manual.
-Kohler recommends to modify the steam head to remove the wax motor, spring and snap ring in the housing. Call Kohler for instructions.
Jan 15, 2011 | Vibrant KOHLER Steam generator control kit...
I have a Kohler K-7 steam generator/shower and after using it just fine, water now just pours out of the steam outlet - even if the unit is turned off at the control head. I have had to close the inlet...
There is a float valve interior of the steam generator that supplies water to the generator unit. There are no parts available for that unit, and Kohler was useless re: repair. I have the same unit and mine is doing the same thing. I took it apart and there is a washer worth about a nickel that is inside the unit. I flipped the washer over in mine and it worked for about a week....then back to the same problem.
Dec 05, 2009 | Kohler K-1698-G Brushed Chrome Tandem...
Kohler Fairfax shower faucet repair
You will need to buy the o-rings to fix it. You can buy at most hardware stores if you know how to turn off the water you can fix this with more instructions. Let me know if you need more help.
Sep 27, 2009 | Kohler Fairfax Single Control Lavatory...
Error code Prr on Mr. Steam control unit. Steam generator starts for about 10 seconds, but no steam comes out and error code "Prr" shows on control unit. Any insights?
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Sep 15, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
The kohler steam unit keeps shutting down prematurely
Since I don't have your model number for this, I am going to attempt an answer for you. Yes, there could be a filter but not always. Sometimes, the sensor on these units can become stuck closed and is sending a false error. Does the unit seem to be working? If it is, then it probably is a false signal. If not, the there could be debris that has gotten into the water lines. Either way, if the unit is new, then it will be under some sort of warranty. I would contact either Kohler or an authorized service rep.
Apr 05, 2009 | Home
Water coming from showerhead and bath spout at same time
Have whoever installed the shower set come back and fix the diverter. It should be a relatively simple adjustment.
Mar 15, 2009 | Kohler Home
Home Logo
1,667 people viewed this question
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
