There is a small short whirring noise when you push the joystick, but absolutely no movement. It was plugged in for about 18 hrs. Also this unit hasn't been used in several years, but it was fine last time it was used. Update - Now all the lights are flashing 8 times.
Hi flashing lights 8 times (Controller fault.). if the batteries haven't been used for several years U might have to replace them .U can buy a BATTERY LOAD TESTER OF E/BAY cost approx,$36..this will give U an accurate test on the condition of the batteries ,good luck
Testimonial: "Thank you, we will check."
The AMBER service indicator will light when an error or fault occurs. This is a yellow wrench shape. Refer to Diagnostic Codes on page 33 for a listing of the flash codes and what they indicate:
https://www.phc-online.com/v/vspfiles/V4_Backup/docs/MK5-NX_Electronics_Manual.pdf
