SOURCE: How to open Hp P2055d laserjet cartrige
If you go to hp.com/support type in your product, open manual should show you pictures of step by step instructions.
SOURCE: Paper Jam at HP LaserJet P2055d
There is output sensor where the papers come out, make sure its lowered down, be VERY CAREFUL not to break it.
SOURCE: i AM USING HP laserjet P2055d printer and its
Hi
the last sensor on your printer it is stuck
check fro paper on it or if it is broken
Pls vote me to keep me alive
SOURCE: when hp laserjet p2055d printer
This happens, usually when a user is not carefull about removing paper from the exit bin. Normally what I find is that the flag that detects paper exits is stuck. There should be a small set of fingers that pop up as the paper exits. If the do not move up and down smoothly then this is where your problem is. Most times if you wiggles them around and push down they should reingage properly.
