Renault Kangoo (KC) 1.4 i car bodywork specifications: Renault Kangoo is a minivan with 5 seats and has 4 doors. Dimensions information of car: 3995 mm long, 1827 mm high, 1663 mm wide. Other Renault Kangoo (KC) 1.4 i cars specs: 2600 mm wheelbase, rear track has 1418 mm, front track has 1405 mm, ground clearance - 140 mm. Total car weight is 1155 kg and 1665 kg of maximum weight, cargo capacity (volume) if from 650 to 2600. Tires type for Renault Kangoo (KC) 1.4 i is 165/70 R14 T. Car engine specifications: 1390 cm3 displacement, located front, transverse with in-line cylinders, 75.8 mm bore. Renault Kangoo (KC) 1.4 i has 4 cylinders. More car engine information: 9.5 compression ratio, 77 mm stroke, car has 2 valves per cylinder, distributed injection fuel supply type, engine power 75/5500 hp, engine torque equals 114/4250.
Transmission specifications of Renault Kangoo (KC) 1.4 i wheel drive is front, it has 4 gears of automatic transmission,.
Renault Kangoo (KC) 1.4 i has wheel-rail type of steering. And hydraulic system power steering.
Rear brakes are drum brakes. Front brakes specs: ventilated disc brakes.
Performance Renault Kangoo car data: it takes 17.3 sec. for Renault Kangoo (KC) 1.4 i to get 100 km/h speed. 147 km/h is the max speed. Renault Kangoo gasoline tank has 50 liters capacity. The car consumps 9.5 liters in the city, 6.3 liters on the road.
TMTM
