Question about Vector WLB26MCP Standard Flashlight
Charger sel for WLB26MCP what does this charger belong to?
I have a car charger MiTAC CA-051-00U-09, S/N 289369GOJ1500. I'm note sure what it belongs to.
It belongs to a Navigation System (Megallan) or a Palm Pilot.
May 18, 2012 | Cameras
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 07, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Need to find a new instruction book and a new charger for a sony cyber shot cammera.
You can download the manual from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCW70
One source for the battery charger is
https://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=605004&searchOperation=modelSearch&searchText=NPBG
Nov 11, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
I need a charger not the battery . the charger to
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=RJrVzlsWIXw2lQjto_2vY0C
Jul 14, 2010 | Sony Cyber-Shot DSC-S75 Digital Camera
I have the Vector Power On Board Bright Bar model WLB26MCP and I need the recharging device. How can I get one. Thank you, fnnsmith@aol.com
You can purchase one from Black and Decker, Vector was purchased from them in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?r=No%20%Results
Oct 05, 2009 | Vector Power On Board High Intensity...
Charger for a Bissell Spot Jifter
I had the identical problem -- a box full of combined chargers! Bissell tech support (1-800-237-7691) informed me Feb. 23, '09 that the 1715 charger/cord model number 203-2506 is 4 amps.
Feb 01, 2009 | Vacuums
Vector WLB26MCP Standard Flashlight Logo
354 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Marvin
Marvin
freddyfox
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
