Question about Roland Audio Players & Recorders
Please tell me what is the best mixer for electric percussion items like roland spd 20 and roland spd sx...please tell me im from srilanka
  • chanaka
    chanaka Nov 06, 2016
    i want chanel 8 or chanel 12 mixer
    Top Expert:
  • Roland Master
  • 51,872 Answers
Fixya is not a buying service.
Posted on Nov 06, 2016
  • chanaka
    chanaka Nov 07, 2016
    i know..i want get answer only about it not other thing
5 Suggested Answers
SOURCE:
SOURCE: Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
Posted on Aug 26, 2008
SOURCE: roland Spd-s pad #1 change to different patches when hit
I'm an experienced SPD-S user and there is no option that allows the SPD-S to produce random sounds from the same PAD.
I can think of 3 reasons why this may be:
  1. In patch mode, a PAD can be assigned with 2 different sounds (wave A & wave B). Wave A will be produced on soft hits while wave B will be produced on hard strokes. To ensure only 1 sound is produced by a specific PAD, make sure no sound is selected in wave B (only wave A will be produced regardless on the force of the stroke).
  2. Your PAD has a very strong and moving effect turned on (such as a phaser or a filter) that makes your wave to sound different between hits. Turn off the effect (press on the Effect button until the light is off) then hit the pad again to see if it fixes your problem.
  3. If none of the previous 2 solution fixes your prublem then your SPD-S is probably malfunctionning.
Posted on Mar 23, 2009
nickmanton
  • 24 Answers
SOURCE: How to recover files from a crashed Compact Flash on my Roland SPD-S?
It's possible your CF card is full.
1. Connect the card to your computer as you have done. 2. Copy the files off it and save same them to a folder on your desktop.3. Right click only the Flash drive and navigate to "Properties" or "Get Info" if your a mac user.4. Take not of the file system it is currently using.5. Re-format the card with the same file system using your computer.6. Replace the card into your Roland SPD-S and Re-format using these steps: a. Select patch mode or wave mode. b. Press {SHIFT} and {SETUP} (CARD UTIL) c. Press the PAGE buttons to select "CARD FORMAT" then press {ENTER} d. A"[>] to format." indication appears. Press [>] e. A "format, sure?" indication is displayed. Press {ENTER} to start formatting.
7. Once formatted you can replace the card in your computers card reader and copy the files you backed up earlier onto it.8. Re-place the CF card in your Roland and it should work. If not then you may have a irreparable CF Card.
Posted on Oct 26, 2012
  • 3698 Answers
SOURCE: Roland pad spd 20. Nothing is coming in display.
Usually the bulb is burned out.
www.rolanddga.com/.../support/video/?.
Posted on Jun 15, 2014
Can you please tell me the best amp that I can use to hook up a Roland SPD 30, I'm looking for one to get volume. ( loud ).
Hi, With my sound engineers hat on I would use a small PA. mixer, amp and speakers!!!!
For quality you need a full, flat frequency range system with good headroom.
I assume this is for your own listening, when using an acoustic kit?
There are one box solutions.
  1. Drum amps. Like a monitor wedge with an amp, Roland do a PM-10, Various other makes are available.
  2. General purpose powered wedge.
  3. Keyboard Amp, these are full range and available in various sizes.
  4. Bass amp with high frequency driver (tweeter), not the best but will have good bottom end.
  5. Powered or active speaker, much like a powered wedge, but a different shape, needs an input volume control.
All these systems need to have large bass units, 10 inch minimum, and will be in mono. Two will give you stereo,
How loud depends primarily on the sensitivity of the speaker. But manufactures insist on selling things by power. Worth looking this up.
At a couple of feet away, 20 watts should do it, with high sensitivity speakers, more likely you find most things as above start at about 70 Watts.
Good luck, I hope I have widened you choices a bit.
All the best, Chris the Fader.
Oct 03, 2014 | Roland Spd-30 Drum Pads
Roland spd 20 analog test error+reason
The adaptor for the SPD-20 is not 12 V ac (Altern Current) the SPD-20 need only Altern current (12V AC)
if the adaptor is 12 v cc, the internal circuits can not made +5v , 0, -5v
for simetrical operactional supply.
And Spd 20 show "Analog test err" and "batery low"
Jan 08, 2012 | Roland Spd-S Sampling Percussion Pad...
How much is a roland octapad 8
new - $699.00
http://www.bhphotovideo.com/c/product/672889-REG/Roland_SPD_30_OCTAPAD_SPD_30_Digital.html/BI/1239/kw/ROSPD30/kwid/KBSHVT71
Feb 28, 2011 | Computers & Internet
How to delete the tracks on my roland spd-s that Ive made Ive had it only for 3 days
Permanently erasing the currently selected wave.
1. "[>] to delete." is indicated. Press [>].
If you hold down [SHIFT] and press [ALL SOUND OFF] in wave mode, you can jump to this screen.
2. A "delete, sure?" indication appears. Press [ENTER] to execute the deletion, or press [ "now processing.." is displayed. After execution, a "complete!" indication appears and the SPD-
S returns to the wave mode.
Source: page 51 of the user manual
pdf download: http://www.roland.com/products/en/_support/om.cfm?PRODUCT=SPD-S
Feb 02, 2011 | Roland Spd-S Sampling Percussion Pad...
The display just showing(welcome to spds) nothing else. please help
I had the same problem after trying to do the update for the flash card (v1.20). I'm taking it back to the store now. I tell you what they tell me...
Aug 09, 2010 | Roland Spd-S Sampling Percussion Pad...
How to reset my roland spd-s
You can reset Roland SPD-S by using Roland SPD-S utility CD supplied with product.
If you can't locate (or lost) the CD that is included with the SPD-S which contains the factory data, you can download the file here:
http://www.rolandus.com/products/pro...37&ParentId=61
Click the downloads tab and select the "SPD-S Factory Restore Data" (PC or Mac) link.
I think it helps.
If you have any query regarding this issue leae a feedback we were happy to assist you.
Have a Nice Day!
Oct 14, 2009 | Roland Spd-S Sampling Percussion Pad...
Removing files
Hold down the "Wave" and "Setup" buttons at the same time while powering on the SPD-S. This will turn off the protection; you should now be able to remove the file.
To turn the protection back on, perform the same procedure again.
May 24, 2009 | Roland Spd-S Sampling Percussion Pad...
Need User Manual for SPD-11
ftp://ftp.roland.co.uk/productsupport/Manuals/
Dec 13, 2008 | Roland Spd-S Sampling Percussion Pad...
May 13, 2008 | Roland Spd-S Sampling Percussion Pad...
104 people viewed this question
Top Roland Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
