1.Manually turn on the component you want the remote to control.
2.Press and hold the component key (TV, VCR, Etc..) you wish to program. The illuminated ON-OFF key turns and remains on.
3.While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4.After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5.Release both keys. The illuminated ON-OFF key remains on.
6.Press
and release the ON-OFF key repeatedly until your component turns off.
Wait four seconds between each keypress. Each time you press the ON-OFF
key, the illuminated ON-OFF key blinks and the next code in the list is
sent. This process continues until all of the codes in the Code lists
have been searched. If your component turns off, you have found the
correct code.
7.Once you have found the correct code, you must save
the new code by pressing and releasing the STOP key. The illuminated
ON-OFF key turns off. You must press the STOP key to save the code or
the correct code will not be stored.
Hi
I loose may manual for the control remote Jensen model Jer-321 and I do not set up it to use into sony tv. can you share the steep to use it
Look for user manuals at http://www.user-manual-search.com
Victor, I tried to help you with this under paid support, and you aborted the session on me.
Please contact me again and I will help you with it
Mike
SOURCE: User Manual for Jensen JER-321
i found the answer to my problem on one of fixya's message board.
THANK YOU. i turn on the tv using the remote then i pressed on the display key and a miracle happened, my tv was working.
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's
right say it with me....He...Rocks...hehe...but anyway here is the link
address if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
I have a JENSEN universal remote control jer 321 and i can't set it up because I loose the instrucctions with all the codes.
code program
Can you give me please a codes of toshiba
I lost my manual of JER 321 and I needd de code of TV samsung
