If it is only leaking when you use warm water it is likely a leak from the delivery side of the hot water inlet solenoid. The only way to check is to remove the top and look.
Hi, Please be more specific. Is it leaking from the bottom of the bread pan, or is there a crack in the side. Usually if it's leaking water or oil from the bottom of the pan, then the sealed bearing is failing and a new pan is needed. Hank
it's your pump! thats the most common leak on kenmore top loaders.it located low ,front and .you can tip washer back towards wall and inspect.the pump is white and has two hoses to it.
