Question about Jules Jurgensen Watches
How to open my jules jurgensen automatic wrist watch
    Champion:
  • 238 Answers
Take it in
Posted on Nov 24, 2016
5 Suggested Answers
SOURCE:
escapement
  • 2338 Answers
SOURCE: How do I change the battery of a Jules Jurgensen pocket watch.
First you have to get an eyeglass and examine watch caseback. Can you see the joint or is it monoblock? If there is joint, get strong knife and press into it. Some of watch casebacks are very tight, so, apply great pressure but do not let the blade slip or you will damage the movement.
If the case is monoblock, then you have to open it from dial side.
Be very carefull when doing it as any slip of the blade will damage your watch.
Good luck.
Posted on Dec 19, 2008
  • 183 Answers
SOURCE: Watch Instruction manual
The best thing to do for instructions for a Jules Jurgenssen is to contact them. You may also try retailers who carry their product.
Jules Jurgensen Helbrose International
101 West City Avenue
Bala Cynwyd, PA 19004
USA
Corporate Phone: cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-220-1233cb_transparent_r.gif
Posted on Sep 23, 2009
HarryHarley
  • 343 Answers
SOURCE: Needs battery replacement
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here's my suggestion. Take it to the jewelry dept at Walmart. Do you have one where you live.
They'll replace for free - Battery $8
Watch how they do it with their tools and you'll know how to do it yourself in the future.
Good luck
Posted on Jan 21, 2010
escapement
  • 2338 Answers
SOURCE: Looking to adjust the size
For removing or adding links firstly you will have to remove bracelet pins or screws. In case if there are screw on each side of bracelet - you have to use two screwdrivers simultaneously. In case if there are pins - read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together (screw ends and pin end may look similar). Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and try to unscrew one. If it turns, but doesn't come out, that means you have a pins instead of screws. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer. Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few punches check if the split end is coming out and when you see that the pin end is coming out long enough - grab it with pliers and pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Posted on Feb 25, 2011
Where can I find out the price of a Jules Jurgensen ladies wrist watch using the serial number on the back?
Sorry we have no way to quote prices here, but a local Jeweler can help with that.
Jul 02, 2017 | Watches
Do you replace batteries in wrist watches? Are you the company the warranty indicated for service?
Yes you can replace batteries in wrist watches. And No we are not the company warranty indicated for service. Try contacting your local distributor to help with directions for service office.
Hope this solution has been helpful?
Apr 12, 2011 | Jules Jurgensen Watches
Can i get a phone no. for jules jurgenson co to get extra band pieces because my watch is too tight to wear
mcdevito75 Here, I did a Fast Search and found a customer service number for Blue Dial a Jules Jurgensen Dealer, nothing on the main company though. Blue Dial may be able to help, it"s a toll free number, 1-877-518-9396 Hope this helps.
Sep 13, 2010 | Jules Jurgensen Watches
Hi there hope you can assist me. My first question to you, and thanks lots I have a Jules Jurgensen watch, and it arrived brand new without a battery. 1) Does a battery for a 7837BR normally...
All watches should arrive with battery fitted. As now there are too many variations of watch movements, it's impossible to tell exact battery code without seeing the watch. Nearest watch repair shop will be able to tell you that.
Jul 30, 2010 | Jules Jurgensen Watches
USA
Sep 22, 2009 | Watches
Dont know how to open the case of my jules jirgensen pocket watch
Its like a clasp just use a knife an open it at back case you can groove where you placed the knife tip.
Hope it may helps:
Jun 21, 2009 | Jules Jurgensen 7381 Pocket Watch
Good luck.
Dec 18, 2008 | Jules Jurgensen Fisherman 7485 Wrist Watch
Good luck
Dec 12, 2008 | Oakley GMT OAK0531 Wrist Watch
Watches Logo
215 people viewed this question
Top Jules Jurgensen Watches Experts
Arturs Kalnins
Arturs Kalnins
Tom Chichester
Jim Dowell
Are you a Jules Jurgensen Watch Expert? Answer questions, earn points and help others
