Sharp AQUOS LC-70LE650U 70" LED TV 1920x1080, 120 Hz, HDTV Logo
Dave H Posted on Nov 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp LC-70LE650U blinking code 2 slow 5 fast
Already changed powerboard with no luck
Level 3:
Top Expert:
  • Sharp Master 76,851 Answers
  • Posted on Nov 06, 2016
Sharp Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003318
Points
237762
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Some models of Sharp TV uses Philips main board. If your TV has such a board fitted, you should follow the blink count procedure for Philips. From your description itself, I do understand that your TV is fitted with such a board. The blinking code procedure seems so.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
I have a 70 inch aqua Sharp Tv. The standby light blinks 2 times slow, 5 times fast. I reset the TV. Nothing changed. Please help. Model number is LC-70LE857U.
Sorry I don't work on Sharp sets so I don't know what the flash code means, do some searching online for what the issue is
Sharp has 2 slow flash and 5 rapid flash what can be the issue?
I have no idea why you would change the power board 3 times, this is the one board that can be tested with a simple multi meter, voltages are marked on the board, ifor future reference you know the 5 volt standby is working, next thing to test is the PS_ON pin coming from the main board, there should be about 3 volts there when the set is turned on, if no voltage replace the main board, if normal power-on voltage test the other rails, if all good the power board is working. Also a tcon board will never give the issues you have, a bad tcon will give distorted picture or blue screen without a picture. Now for what's wrong, according to service lit the blink code you have is bad inverter-backlight issue, since this set is LED it doesn't have an inverter so it's a LED backlight issue. Replacing the backlight strips should correct your issue, unfortunately on a set this size and with it being edge lit replacing the strips isn't a real easy job, this set has a diffusion panel behind the panel (screen) and it has to be replaced correctly or the picture won't look right, also with this size panel extreme care must be taken when handling the panel, suction cups work the best for removing and replacing it. Good luck!
Sharp TV has no picture. Blink code 2 plus 5
Throw away product like most modern sets
70 sharp aquos tv. light blinks five times, two slow
I have a 70 inch aqua sharp tv. The model number is LC-70LE857U. The stand by light blinks 2 times slow, 5 times fast. Tried resetting the TV.. Nothing changed. Please help.
My 70in sharp aquos lc-70le650u will turn on and work fine with great picture and lighting then after about 5 mins it cuts off and the power indicat or blinks 2 times slowly and 5 times fast
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Sharp tv 70 inch wont turn on blinking 5 times fast 2 times slow
Which model do you have because the blink code differs from model to model. Did you try a hard reset? Meaning, unplug the unit, wait a minute or two, then holding the power switch down, plug the unit back in while still holding the power switch down. When it comes back on, release the button.
I have a sharp aquos lc-70le650u, will not turn on, power light flashes rapidly 2 times then 5 times
I'm not sure about this one since I never worked on 1 of them.. But I did find a link that you can check on. http://www.badcaps.net/forum/showthread.php?t=41773. Good luck on it
1helpful
Sharp LC-70LE650U not powering up flashing icon 2 slow 3 quick which circuit at fault?
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
