Is it an aftermarket radio or original equipment, if it's an aftermarket radio the yellow wire not may not be connected properly, with a few other possible wire connection issues the yellow wire should be most common.
If its original equipment there's two fuses one underneath the hood of the car and one underneath the rear seat if both fuses are good most likely radio unit itself has crapped the bed, you can get one at the junkyard for anywhere between 25 and 75 bucks
This is why walmart and others sell a wiring kit that plugs one end into the stock wires and the other to your radio, One hot ware goes to always hot wire for clock and station presets, other goes to switched ignition so radio goes off with the key.
2002 GMC Envoy Car Stereo Wiring Chart Car Radio Battery Constant 12v+ Wire: Orange Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power. Car Radio Ground Wire: Black/White Car Radio Illumination Wire: N/A Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Dark Blue Right Rear Speaker Negative Wire (-): Light Blue
The wires that control the radio from the steering go to the Body Control Module (BCM), not directly to the radio. The BCM sends data over the serial bus to the radio.
Check the fuses for the power outlets.They are separate than the cigar outlet.They are located under the back rear seat on the drivers side.It will be fuse number 46 for power outlet 1 and 15 for outlet 2.Hope this helps.Good luck.
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
