I thought it was becuase I pressed start prior to picking another menu option so turned off the poiwer for 15minutes to flush out the memory. But an hour later I still have the same problem.
This is normal behavior for this breadmaker to default to 3:15 - just press and release the MENU button a few times to advance through the menu options. If it is "stuck" and won't advance through the menu options, hold in the stop/pause button for almost 15 seconds until the machine resets back to 3:15. THEN, press and release the MENU button a few times to make your selection.
Plug the flash drive into the Xbox 360 USB port in the front of the machine. Hold the middle button on the Xbox 360 controller to boot the console.
Scroll to the "My Xbox" screen with the d-pad. Move right to the media option you want to access. For example, the "Video," "music" or "Picture" options are available.
Select the type of media by pressing the "A" button. The next menu is the same for all three options. Highlight "Portable Device" and then press the "A" button again.
Choose the content from the next menu. On the right side, pick the file or folder of the media you want to display with the d-pad. Press "A" again to select the folder or to play the media file.
