Lands Phones Logo
S
Saad Soubra Posted on Nov 04, 2016
Avaya 5410 answering machine not working - Avaya Lands Phones
5 Related Answers
A
Anonymous
  • Posted on Sep 25, 2009
SOURCE: how to setup voicemail greeting on Avaya 5410
Dial into vociemail enter your extension number followed by pound. Enter the password and #
Press 3 for greetings.
enter greeting number (1)
press 1 to record a new greeting.....
A
Anonymous
  • Posted on Oct 04, 2009
SOURCE: avaya 5410 phone welcome message - how to change?
What voicemail do you have?
A
Anonymous
  • Posted on Jan 13, 2010
SOURCE: I need to reset my avaya 5410 voicemail password
You will need to log into Mnager (the IP Office management application). Go to the users section, and click on the Voicemail tab. delete the stars. Then save the config.
When you log in the first time, there isnt a password, so just hit #.
A
Anonymous
  • Posted on Jul 30, 2010
SOURCE: AVAYA 5410- want to turn Caller- id off
Do you have access to Manager? You can tag the incoming call which does not show the caller ID of a call until the call is answered.
Anonymous
  • Posted on Mar 16, 2011
SOURCE: Message light on an Avaya 5410 phone will not go
NG shows up next to the name
2answers
Change my answering machine greeting on avaya 5400
Do you have voicemail pro or embedded voicemail? Do you have the right document?
2answers
Is it possible to get caller ID for an incoming call if I have that number saved as a speed dial? If so, how do I get that. My phone is the Avaya IP Office 5410. Thanks
If the number matches the CID number, you should get the name as well. But here is the hard part.
IF your system requires you to dial an access code (say 9 to get an outside line) you may have that speed dial number saved as:
913125551212
If so, the incoming caller ID would have to match exactly, meaning CID would need to show 913125551212 in order for this to work.
BUT, caller id probably only shows 13125551212, and as such, wont work.
Hi I need to re set the number of rings on my Avaya 5410 anwerphone before it answers because it takes ages. How do I do it?
You need to do this in the Manager application. Under the telephony tab of the user, you can change the "No Answer" time.
2helpful
2answers
How do I set up voicemail on the 5410
Press the voicemail button and follow the prompts. You will need to know what the password is. When prompted for the password, try just pressing #
2answers
2answers
Cant get Voice mails
Try to delete all the messages then try adding a voice mail dialing from another extension then you will recieve the messages.
Plantronic 510s
The Voyager 510 is not a good fit for that phone. I would prefer the cs55 or awh55.
The headset will work with the phone, but will not alert you when there is a call.
Top Avaya Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
