Question about Stanley Garden
Stanley pressure washer keeps cutting out - Stanley Garden
Stanley P1800S pressure washer lost pressure after a few uses
The valve-o-rings + [ parbaks seals ] where the pressure can be adjusted with.
Control the water inlet filter or hose that there are no waterlock couplers are used or is mounted
on the wrong site on the hose , that it is used as water inlet on the tap.
Dec 25, 2016 | Stanley Garden
Stanley motorised pressure washer. Cant get the water to flow
Disconnect the wand from the washer if you get water coming out of the discharge, the problem is in your wand or the line is plugged going to the wand.
Feb 27, 2015 | Stanley Garden
My compressor will not cut out when up to pressure what can the fault be?
You have a pressure regulator somewhere on the unit that is adjustable for low pressure kick in and high pressure cutout. Turn the high side out after pressure is where you want it to cut off and it will do so. Low pressure cut in should stay where it is.
Nov 29, 2014 | Stanley Air Tools & Compressors
Stanley instruction manual
There is a spring in there that makes it recoil. It has probably broken. Depending on who made the engine you can get a replacement for the whole assembly. A small engine shop should be able to replace it for a not a lot of money.
Aug 14, 2014 | Stanley Gas Pressure Washer: 2750 psi 6.5...
I own a stanley pressure washer and it keeps tripping out
The pump will cycle on/off but if it works properly when you pull the trigger and it keeps working then its working correctly.
Jul 20, 2014 | Stanley Air Tools & Compressors
Xtreme pressure washer keeps cutting out.
you have to be more specific in your questions. Is this a gas or electric machine? What happens when your machine fails? Does it spray fine for awhile and then cut out? Does it cut out when you turn it on? Give us symptoms .
May 07, 2014 | Garden
My stanley compressor will not shut off untill the safety pop off valve activates
The pressure cut off setting is too high. Locate your operation manual and adjust the pressure to the manufactures specs. Normal shut off pressure is @ 125 psi.
Feb 15, 2011 | Stanley NEW Bostitch 2 HP 6 Gallon...
Leakage from the garden hose connection along with connection to the pressure washer.
The female hos bib connection should have a typical hose washer inside.Often you can't tighten the nut tight enough without this washer, to keep it from leaking both from the hose, and the rest fo the fitting into the washer.
Jun 14, 2010 | Stanley 1600PSI Pressure Washer w 20ft...
Pressure washer keeps cutting out
Carb problems: needle seat is sticking!
Dec 08, 2009 | Garden
Garden Logo
151 people viewed this question
Top Stanley Garden Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Andrew Taylor
Andrew Taylor
Are you a Stanley Garden Expert? Answer questions, earn points and help others
