Re: How do you contacts from memory card to blackberry...
The memory card can be accessed by pressing the Blackberry button and choosing SIM address book. If you want you can then transfer them to the phone memory.
Hi feziwe tamba first pull the battery and the memory card from the phone. If you don't have a memory card I highly recommend you get one. BEST BUY MOBILE,WALMART, RADIO SHACK any retailer will have them. This solves to a few common problems. All phones have a limited memory space. I recommend a 8gb as the smallest one you want to put in your phone. Now depending on your carrier you need to make sure your phone has the data coverage also. You may not have enough data coverage for the webchat program. This sounds like a memory issue. Also how are you trying to open the web chat. You may want to open it using the blackberry world app. This are apps that are made to run on blackberry phones. If you have more issues feel to contact me again.
Ok there are some things you need to do.
1 you need the disc that came with your 8520 This disc help you load desk top software. 2 You will need to backup your phone. You can still use this older software.It was make for the older blackberry. Now is your phone for personal or business. If you can backup all your important information on a 8-16 gb micro scan memory card. The more gbs on the memory card the more room you will have.If you need help ican walk you through the process on your computer. The curve is an older blackberry. It can be a memory problem. I suggest you get a bigger memory card and put it into your phone.
first of all try inserting the memory card into other phone if it works then format it and re-insert it again.if still it does'nt work then check out your memory card jack present in blackberry.
insert your memory card and go to your scroll your menu to file then you find Phone memory and memory card then click on memory card on top of a conatct you have there press your option and scroll down where you will found mark, mark all then click on mark all and then it will ask copy or move then you click either one of the two then it goes immediately ok.
regarding your problem, i think you must try to reformat your card using your new phone (blackberry bold 9000) for you to be able to use that card in the said phone.
just let me know if you need more further assistance. nice day.
If it is your sim card you are speaking about all you need to do is press the BlackBerry button and choose SIM Address book and it will display them from there you can move them to your Phone Memory.
