I have the same series of 5 sony vpl-dx100 projector and keep them for the past 2 years. now that i intend to use them, they do goes on standby after like 10 seconds of display. What can i do to solve this issue? I am not sure its a factory problem because i used of the 5 projector exactly like 2 years ago and it worked then but its currently not working too.
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
SOURCE: Sony Projector VPL-VW 10HT 2 problems 1)The
there is a lock on the projector that needs to be removed. check the manual for the code.
SOURCE: Projector problems
Hello!
After 2 years I finnaly solved the problem. There was a flaw in the
lamp´s temperature circuit. A technician disassambled my BENQ PB8253
unit and fixed the problem. Charged me US$ 75.00. I´m in Brazil.
Hope this can help.
