Question about HTC Computers & Internet
My HTC FLO TV PTV 350 WHEN POWER UP ITS STUCK ON FLO TV SCREEN WHAT CAN I DO TO GET PASSED IT
How can I reset my Flo tv htc
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jul 05, 2017 | HTC Cell Phones
Ptv biss key
how to put biss key in ivoom 707 recver
May 10, 2013 | Televison & Video
I forgot my HTC touch flo password and I can't
do a factory reset on your phone,
vol button down + OK button ( center ) + power button
hold them all at the same time and use stylus to reset your phone on the bottom
tricky but works just fine
you have to keep holding them until u see the msg on the screen
Jan 26, 2013 | Cell Phones
Touchscreen is spoilt and i need to start the phone with my original settings
my HTC touch Flo touch screen was out of function, i had done hard reset, but window mobile required user to tap the screen to set up window mobile based device. what shall i do next?
Apr 11, 2010 | HTC P4350 Smartphone
Touch flo background...
its probably the default but with windows you most likely cant change it
Jan 22, 2010 | HTC Touch HD Smartphone
Touchflo does not appear to be working on new Touch diamond
TouchFlo is an application that needs to run on top of Windows. It is quite well hidden in the menus....
To start with, I assume you get the normal Windows Mobile 'Today' screen? If not, you have bigger problems!
If so, hit "Start" --> Settings
Then on the 'Personal' tab, go to 'Today'
Then look at the 'Items' tab and make sure that TouchFLO 3D is the only checked item.
Hit 'OK' top right, then 'X' top right and you should get back to find it activated.
@deepak - TouchFLO 3D is standard on the HTC Diamond. If you have TouchFLO then I guess you have a HTC Touch (different phone).
Dec 02, 2008 | HTC Touch Diamond Smartphone
Bizhub 350 copier lcd just blue no menu display
IF WHEN power up machine goes to a bright blue screen and then the machine is stuck and it does nothing further.
Description:
Blue screen and the machine is locked up.
Solution:
CAUSE: Failed control panel (UN1).
Oct 29, 2008 | Office Equipment & Supplies
Computers & Internet Logo
291 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
