Canon XL2 Mini DV Digital Camcorder Logo
Posted on Nov 03, 2016
Cannon xl2 camera will not show proper year/goes from 2004 to 2030
1 Related Answer
Anonymous
  • 10 Answers
  • Posted on Mar 06, 2011
SOURCE: my canon mini dv camera model no> xl2 is in
If you can't find the manual on Canon's website it's probably not a good idea to go elsewhere. Your best bet is to send it in to Canon and have their techs repair it.
Canon xl2?
Yes, it exists sir. It is a mini, digital video recorder.
Canon XL2 3CCD MiniDV Camcorder w/20x Optical Zoom ...
www.amazon.ca > Canon-3CCD-MiniDV-Camcorder-O...
From the Manufacturer. The Canon XL2 allows you to capture images closer to the finished product than ever before. Work that previously was limited to post- ... Rating: 4.4 · ‎28 reviews
Canon XL2 MiniDV Camcorder 9549A001 B&H Photo Video
www.bhphotovideo.com > ... > Camcorders
The Canon XL2 is the upgraded replacement model of the ground breaking XL1 camera. It is still the only prosumer camcorder to offer an interchangeable lens system. Rating: 4.5 · ‎30 reviews
Canon Xl2 Camcorder for sale ' eBay
www.ebay.ca > ... > Camcorders > Canon Xl2 Camcorder
Results 1 - 11 of 11 - Canon XL2 3CCD Digital Camcorder W/ 20x Zoom xl 5.4-108mm L IS 1:1.6-3.5 Lens. 4.5 out of 5 stars. (39) C $188.76 shipping.
Support ' Support Professional Camcorders ' XL2 ' Canon USA
www.usa.canon.com > portal > home > support > details
XL2 · Standard Definition or High Definition · Power Supply (rated) · Power Consumption (While recording AF=ON) · Television System · Video Recording system.
2helpful
WHEN I INSERT A CASSETTE THE CANON XL2 SAYS REMOVE CASSETTE
This can be caused by several things such as an oxidized video drum, a failed component in the tape detection circuit or a transmission gear not engaging properly. All of which can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
My canon mini dv camera model no> xl2 is in
Lcd flickers and shows different colors from red to green to purple and the manual exposure settings won't work.
I have found that the problem you are having is a result from a bad lcd cable that goes from the lcd pcb to the main pcb or a bad lcd panel itself. I hope this helps.
2helpful
3answers
Camera picture not shown on screen
It could possibly be because after selecting the "disp." (display) button several times the screen goes black. Simply press the "disp" button until you monitor will show what your camera see's.
Cleaning tape jammed in canon xl2 camcorder
Take the camera to a reputable camera shop, there is honestly no way to do this at home, if you touch the video heads by accident, or accidently move something, it could spell big trouble. Also I to have an XL2, and canon might be willing to fix this for free from what I understand about their customer care plan (Best Regards)
Do i need compassitor i have stock radio with brand new subs with XL2 1600 amp
This commonly happens when the ohm load is too low. Double-check the wiring to confirm that the speakers are wired properly.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
