SOURCE: transfer my video from panasonic sdr - h40
try to use USB to plug your device to your computer. make sure that you have an installed driver for your camcorder to recognize your device on your pc. all brand new camcorder came with an installation software cd. now your ready to transfer your video to your computer. use any movie maker application like ulead movie maker, nero movie maker or windows movie maker edit it and save it. burn it to your vcd or dvd burner to play on your dvd player. if you dont have a driver i will find one for you. hope that helps!
CHARCOIS
SOURCE: Need Panasonic SDR-H40 software download
You can connect to any computer with a USB port. It appears as a hard drive after you tell the camera to connect (in the menu). Then just copy the .mod files to a spot on yor computer; there will be one for each movie clip.
Your next chore is changing them into MPEG files at the correct aspect ratio. If you shot in 16:9 they will be squished together unless you use the SDCopy freeware utility to set the widescreen flag. It also renames and downloads files for you, and it's small. There's a link from this tutorial page, which also explains a lot about aspect ratios and such:
http://www.elurauser.com/articles/JVC_Everio_mod_files.jsp
SOURCE: Need software to download Panasonic SDR-H18 palmcorder.
forget Nero - terrible software that costs and arm and a leg - waste of time - thanks for nothing, fparton
SOURCE: Connecting Panasonic SDR-H80 video to PC / Mac without AC lead?
hi, you can record on a SD card that you can then remove and read through an SD card Reader (a usb key where you slip the card and pof! you have it).
For the Mac/ Pc/ Power adaptor I have the same problems. tell me if your quest for knowledge was fruitfull anywhere else.
W
