Question about Jensen VM9510 Car DVD Player
DUAL XDVD700 BYPASS
LOOKING FOR A WAY TO BYPASS THE E-BRAKE, NOT THAT I WATCH THE DAM THING WHILE DRIVING,,,BUT THE WIFE DOES,,,,JUST EASIER TO HAVE IT ,,,IN DASH,,,THANKS
  • 17 more comments
  • Anonymous Nov 22, 2007
    i hurd there is a cood that u could put in that would bypass the ebrake. do u know what it is?
  • 4545 Dec 25, 2007
    i ahve a xdvd700 and i have it hook up but need to bypass the e brake can you help me?
  • Anonymous Jan 01, 2008
    no effect from the pink wire when earth to neg terminal or chassis
  • kinfolkquez Feb 16, 2008
    I just installed my dual xdvd700 and I can't get the screen to open.
  • Anonymous Mar 18, 2008
    THE E BRAKE BYPASS
  • big hen Mar 21, 2008
    the same as everyone slse need to know hoe to bypass the e-brake system
  • Anonymous Apr 09, 2008
    i have a dual xdvd 700 the ebrake safety wire goes to the ebrake safety switch ground so all i did is hook up the ebrake safety wire on the stereo to a ground and it works the screws that hold the dash in place are a good source to use
  • Anonymous Apr 28, 2008
    How do i bypass e brake for my dual radio
  • rieathbaum May 23, 2008
    I have a yellow wire that reads "parking brake" I DONT want to have to rip out my dash to get to it. 2005 Dodge Neon SXT. Can I hook it DIRECTLY to my battery or how? Thanks,Kevin.
  • Anonymous May 25, 2008
    e-brake problems tv will not play at
  • Anonymous Jun 28, 2008
    picture will not stay on
  • Anonymous Jul 16, 2008
    I tried the toggle switch from power and ground but it didnt work...Also tried to ground it with my stereo and then hook the other wire to a power nothing works so far it just comes up with its illegal to drive with dvd playing bs.. what should i do now
  • Anonymous Sep 10, 2008
    I rodeo alot and i need my dam dvd plpayer to work but it wont b/c I dont have the code for it!!!!!!!! Please I need the code!
  • Anonymous Dec 24, 2008
    my ******* dvd does not work wile im driving and i ant to use it when i drive
  • bottomsup19 Feb 10, 2009
    i have a dual xdvd700 can I still bypass the ebrake thing without my remote
  • Anonymous Feb 14, 2009
    i bought a xdvd700today but the screen will not go back in the unit by itself what is wrong or what could it be need help fast bskjordal@yahoo.com
  • dirkdig Feb 25, 2009
    hi i just bought the dual xdvd700 an i have no clue where to start whats with all the rca plugs! i can wire a normal sterio no prob but this has me stumped do i need to buy a specific wiring harness an where would i find it!?
  • Anonymous Apr 23, 2009
    my dual x dvd700 just stopped showing anything on the screen
  • Dregor May 11, 2010
    OK so I am fairly familier with some of the options that are presented here for by passing the Ebrake, but what in the world is the White wire with the brown stripe for?? I know what to do with every wire coming out of the XDVD700 except this one and I have no clue what it is for. Please help.
  • 3 Answers
The way you bypass the E Brake is you have to ground the wire to the radio sleev itself. There are two different peices. The radio itself and the sleeve that holds the radio in place. Take the yellow wire (the ebrake wire, not the yellow ignition wire) and open the metal connector up just slightly. Attach that wire to the top of the sleeve on 1 of the teeth located near the front of the unit. You have to make sure that the connection is good or it will not ground. Next slide the clear plastic over the wire so the only connection is with the tooth.
Then Insert a cd or dvd in the player. Press play on the remote and then push stop 2 X times on the remote. After you have done that press 26604 on the remaote and then press enter. This will permanently unlock the parking brake feature and allow you to watch dvds while in motion. If you need any further help you can eamial me.
Posted on Sep 08, 2008
The XDVD700 by dual is the easiest ebrake bypass to do. Take the yellow ebrake wire and connect it to a ground or connect it to a ground or the same ground as the dvd player itself, both will work fine. 100% functional, it doesn't change anything except for the fact that you can watch the dvd while in motion. Do not waist your time with those bs codes that never work, and if they do they work for about half a movie
Posted on Dec 10, 2007
You can solve this problem by hitting menu on the remote go to set up and turn the video out on. When you put in a DVD it will show you the blue screen still, but will go black hit the mode button twice on the remote and you should see a picture. It may go black one more time just hit the mode button once more and you can watch your movie. These are safty features that come on this player due to it being illegal to watch a in dash DVD player. Hope this helps...
Posted on May 14, 2009
Ok when i open my screen it says put a password??? last time i open it it sayed tha same thing but dis time it had a pop up number pad n i put in 0000 thts the code now whn its open its says 2 put in password but no pop up pops up its like froze i can listen 2 nothing or take my cd out lol... wht can i do whts the problem can u help me
Posted on Jun 26, 2008
    Problem Solver:
  • 5 Answers
If you want you can do the same as i did. Buy a toggle switch and ground one end out to the chassie of the body and the other end up to the ebrake and find a disclosed place to place it so that it isnt visible. When you have installed it open up the audio menu while you have dvd in click the toggle switch for one second then click it again off for a second, back one for a second off for a second. Then back on it will come on with the movie showing.
Posted on Dec 02, 2007
To play dvds on th road.... take the wire from the e brake and hook it to a ground.... when you put in a dvd you will see the blue screen that says dont drive with dvd bla bla bla...... take the e brake wire that is connected to a gound disconect it touch once touch twice and reconnect within five sec you should see the picture if not repeat this step..... Its the wire that says connect to e brake. just hook to a ground and do the double touch and leave connected to bypass the saftey
Posted on Apr 01, 2009
If you put a movie on an ipod the go to video setings on the ipod and turn video out "ON" then when conneted to xdvd700 there will be a little movie button in the top right conner when listing to music with the ipod press that then select the movie on your ipod its self then the movie will show up on the xDVD700
Posted on Jun 01, 2009
Being a radio shack man myself this is real easy to do.
All you need to do is go to radio shack and buy yourself a 12 volt or above momentary push button/switch (about $3) If the button swith/button comes with wires then just connect one end to the emergency brake wire from the radio and then connect the other wire from the switch to a ground to your car. You can use the same ground connection that you used for the radio and it will be fine. make sure you wrap up the wires to prevent shorts.
Also make sure that the switch that you buy can be mounted because you will need to use it every time you want to use the dvd.( you might need to drill a small hole for the switch depending on what you buy)Make sure you have enough wire so you can mount it where you can easily use it like under your steering wheel.
When you are ready to use the dvd put the dvd in the player and after a few seconds the screen will turn blue and the message to "Set the emergency brake" will come on. Now just press the switch/button for one second and release it. The screen takes about 6 second to display the video. If it does not work then try again but this time try to push the button/switch twice. In my truck I only have to do it once and it works fine but you get the idea.
Posted on Feb 06, 2008
I have the same dvd.what i did was hook the ground up from the deck too the ground wire too the car and get the yello wire which should be e brake wire.hook that up too ground wire up 2 the car ground and deck ground.after that u have too kinda play with the right side botton push it in 2 time real fast too engage e brake/
Posted on Nov 23, 2008
Srfse
Posted on May 06, 2008
Conecta el cable de color rosa a la masa del auto o al negatico.... y chau problema
Posted on Apr 28, 2008
Yess it works i used a 3 way switch and it works great
Posted on Apr 27, 2008
Can the Ipod play movies thru the deck. Also put movies on the screen from ipod. thanks
Posted on Feb 10, 2008
Chrysler01 has the right idea. It's the exact same thing my cousin done with his Dual xdvd700....with the toggle switch...then cut it off....on....off....on.....again before each use...usually have to do it twice....it works!
Posted on Jan 07, 2008
How do you play dvd -r or plus r in this headunit cant figuer it out
Posted on Aug 11, 2008
I installed one of these radios today and all we had to do was use a 3 pole switch 1gnd 2acc 3pwr run gnd to a good ground run acc to the yellow/blue wire and the pwr to a power source. Then when you turn on your car turn the switch on...off...on...off wait a sec with every change and when you turn it off the last time and wait for like 5 seconds it will show video till you turn off the car agian.
Posted on Feb 14, 2008
AQUIEN PUEDAINTERESAR TENGO UN XDVD700 Y TENGO PROBLEMAS CON EL SISTEMA MECANICO DEL DVD NESECITO ARGUN DIAGRAMA SOLO DE ESA PARTE LO BREGARON Y NO ESTA EN TIEMPO
GRACIAS DE ANTEMANO ATT CAMACHO CCR1767@HOTMAIL.COM
Posted on Sep 15, 2008
Ground the line, wait 1 second
Unground the line, wait 1 second
Ground the line, wait 6 seconds
..video
I installed a toggle switch that you can do it with quite easily.
Posted on Jan 27, 2009
Splice the yellow wire with the blue stripe into the same black ground wire the unit is grounded to.
Posted on Oct 30, 2008
SOURCE:
XDVD700 Car DVD Player: I'M TRYING TO FIND BYPASS CODE?...
You do not need a bypass code. Pull out the stereo unit, take the parking brake wire and disconnect it from the parking brake sensor ground. Reconnect it to the radios ground wire and this will tell it that the vehicle is always in park and your videos will work while driving. It must be the stereos ground not just grounded to the frame or something. Must be a live source ground wire.
May 18, 2010 | Dual Electronics XDVD700 Car DVD Player
I have a xdvd700 dual and want to bypass the brake thing but no remote is there anyother way?
Usually there is a handbrake connection that needs to be grounded to the chassis in order to bypass the screen lock. I normally wire it though a switch to ground and back to the handbrake, so if the car is inspected it works like it should.
Some units feature a footbrake wire that needs to be pulsed as well. This is harder to override. I use a bypass device from Peripheral called the PAC-TR7.
Dec 06, 2009 | Dual Electronics XDVD700 Car DVD Player
I want to watch dvds while driving gotta a dual xdvd700
my car radio is dual xdvd700 it wont show the image on dvd
Jun 16, 2009 | Dual Televison & Video
Dual xDVD700 won't come on
CHECK VOLTAGE ON RED AND YELLOW WIRES OR RESET THE UNIT.
May 13, 2009 | Car Audio & Video
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
** Take out Audio CD and Insert a DVD
Aug 26, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
Need help on hooking up a xdvd700 dual without ebrake
i have the xdvd700 dual. my screen goes blank when it comes all the way up. is there a solution for that? or is that manufacture's problem?
Jan 30, 2008 | Car Audio & Video
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
Dual xdvd700 want to permanently bypass e-brake
1. Ground the E-Brake wire.
2. Insert a DVD
Let it play until you hear sound
Press STOP twice on remote
Enter 26604
Press ENTER
Oct 27, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9510 Car DVD Player Logo
19,819 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
