Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
Jaycee Santos Posted on Nov 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change language on my KDL-40V2500? please help tnx.
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Nov 01, 2016
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14993052
Points
237762
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ . Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
5 Related Answers
AMJAD HUSSAIN
  • 586 Answers
  • Posted on Aug 06, 2008
SOURCE: sony kdl-40v2500 40
It must be due to the timer which is in Active position.Just check the both timers sleep and On.
A
Anonymous
  • Posted on Aug 11, 2008
SOURCE: Normal picture mode make the sharper picture quality but smaller screen apparance
If the broadcast is in 4:3 (square) then either you can have the black bars on the side, or the TV can stretch the image to fill the screen.
Nothing wrong with your set. The broadcast must be in 16:9 to fil the screen.
Ron F
  • 135 Answers
  • Posted on Nov 14, 2008
SOURCE: Repairing Sony LCD tv
Try getting the TV menu on the screen. If you can't, it's probably the LCD panel or backlighting issues. If you look very closely sometimes you can see a dark image if it's backlighting issues.
If you can bring up the menu, but all inputs are black, then the problem is more towards the electronics. Usually computer VGA and HDMI inputs bypass a lot of electronics and may point you to a video switching issue in the TV. If this is all Greek, consider a trained service company. Choose a platinum servicer since they are Sony trained, certified and held to much higher standards than other authorized servicers. Sony expects them to make first attempt fix within 5 days of contacting Sony. Usually the right part is sent to the tech prior to them setting the repair appointment. Compare that with the others and you will see a clear difference.
djchillsnyc
charlie rodriguez
  • 152 Answers
  • Posted on Dec 25, 2009
SOURCE: lcd is cracked on a kdl-40v2500 soney
hi, if your screen is cracked you will need a replacement screen this type of repair that if you call a service center they wont do becuase basically the screen is the most expensive part it may be more than the cost of the tv when new, theres only one way to do this and not spend a fortune and thats by buying a used tv same model that is not working or for repair, of course it needs to have a good screen, where at auction sites and surplus sites. you can replace the screen if you buy a used non functional at auction and exchange it or repair the other tv with your parts either that or get a new set, it is expensive to fix any other way. hope this helps, happy holidays.
brian soufane
  • 693 Answers
  • Posted on Sep 14, 2011
SOURCE: I lost the cord to
I set up this link below which will take you directly to where you can get a replacement chord.http://www.ebay.com/itm/Sony-Bravia-VPL-HW15-Projector-AC-Power-Cord-Cable-Plug-/310258014614?pt=LH_DefaultDomain_0&hash=item483cd19996
Vertical lines after the tv is been for a minute
If you can open LCD Tv than refit all connector of Mother Board
Broken screen on a kdl-40v2500
No not repair able very expensive,LCD screen will cost the same as a new tv.Tv compannies will not sell LCD screen out reasonable price.
2helpful
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
1helpful
Have a new Sony Bravia KDL-40W500 keeps turning off into standby mode with 8 flashes.
There is some confusion on the model (KDL-40W500 vs. KDL-40V2500), so I will direct this toward the 40V2500.
On the KDL-40V2500, an 8X blink means the scan processer has gone bad, and the BU board needs to be replaced. If the problem is intermittent, the the AU board might be the problem, but if it all the time, bank on the BU.
A competent repair shop should be able to help you, or you can try calling Sony directly for assitance.
Hope this helps you...
How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Sony kdl-40v2500 40
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
