SOURCE: HP Officejet J4580 paper jam
Paper can jam inside the printer for a number of reasons.
SOURCE: how do i clean the printheads on a hp officejet
hp printers have a utility program that cleans and purges the printer heads. Go to HP on your startup menu and look through the options....mine is located in the "hp solutions center".
It has an option for purging the printer heads.
SOURCE: how to use scanner on HP officejet J4580 all in one?
Click here to visit the HP support page for this model. You will find an online manual with complete instructions for download free of charge.
SOURCE: When trying to scan to my HP J4580 Officejet J4580
this means the printer has not been configured to the computer,,
1st check the connection of the printer and the computer,,
then check if all the software like the basic print and scan drivers, hp solution center and the hp imaging device function had been installed or not,,
if all the above things had been checked then
open hp solution center,,
click settings,,
go to scan settings,,
select scan to set up.....,,
you will get two columns there,,
the left will be for the solution center and the right one will be for the printer,,
you will see two arrows in between the columns,,
populate the entries on the printer that is on the right column using the arrowes,,
once done click update device,,
then close the olution center and restart the printer,,
then check it will work................
SOURCE: change language hp officejet j4580
How can I change the language on my HP Officejet J4580 All-In-One Printer from Swedish to English??
