Nikon N60 35mm SLR Camera Logo
A
Anonymous Posted on Oct 30, 2016
My camera wont load film. I turn it on, load the film, close the back but it doesnt wind the film up and it says there is no film in it. But, when i take a picture, it rewinds the film.
I have a Nikon N60, which automatically loads the film. And i load the film to the red dot like your suppose to.
Bill Boyd
Level 3:
Top Expert:
  • Nikon Master 53,816 Answers
  • Posted on Oct 31, 2016
Bill Boyd
Nikon Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948974
Points
172802
Try turning the camera off to load
when loaded turning on should take it to the counter for no 1 film shot
My Nikon N60 wont load film. I load the film but it doesnt wind the film, but when i take a picture it rewinds it. I dont know what im doing wrong
Hi. Pay careful attention to the way the end of the film fits through the take-up reel. Open the back (empty) and give the wind knob a few twists. That will tell you which way it is turning. Put the end of your film through the slot in the take-up reel so itd winds onto itself as it advances. There's usually enough extra unexposed wound onto the factory reel that it won't cost you and pix at the end of it. Pull enough out of the cassette to be sure your winding-load position is really going to hold when you advance. Good luck.
I have a Pentax ME super and the film door will close when there is no film but when i load it with film its not closing properly?
I really loved your camera type though it was 35 years ago I had one. I envy you.
Not sure why you should be having trouble unless you have a bad film. Have you tried more than one film?
If the film cassette has dropped in properly and is laying flat, the film rewind has to be raised, I think, to allow that and the sprocket holes in the film are properly engaged with the sprockets and the free end of the film engaged onto the film wind-on reel then everything should be well below the door aperture.
I would wind on maybe a frame and fire the shutter prior to closing the film door just to observe everything moving as it should and then close the door.
The last quarter inch the door must be closed against the pressure of a spring but if the little spring-loaded device behind the door which is intended to keep the film perfectly flat against the camera body is working correctly only a light pressure will be needed to compress those springs and close the door.
Perhaps something is wrong there?
I don't remember any problems closing the film door.
I hope this helps but if it doesn't please come back again and describe your actions and the feel of the door more fully.
1helpful
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Diana F+ 35mm back wont load film.....
possibly you have a friction padded roller instead of spikes place enough film on roller to overlap and then close camera
2helpful
My x 370 wont transfer pictures onto the film? The camera looks like it's in good condition. The roles come out blank!
Film cameras directly expose film to light to produce an image: they do not "transfer pictures onto the film", but your phrase is a big clue as it suggests you've only used digital cameras in the past and so may have made a very simple mistake with film loading.
If the film is blank as in transparent, then the film has not been exposed. If it's completely dark then it's been over exposed.
I suspect you mean that the film is unexposed as it's by far the most common fault: cameras like the X-370 have completely manual film loading; the film has to be manually engaged onto the take-up sprockets before closing the back of the camera. After that, correct loading is confirmed by watching to ensure that the rewind crank (top left knob as viewed from rear) rotates every time the film winding lever is used. Note that the frame counter will advance even if the film isn't correctly loaded. Once the film is used up, the winding lever won't operate and the film must be rewound back into the cassette before opening the back of the camera. To do this, you press the recessed button on the underside of the camera and use the rewind crank to rewind the film until you can feel no more resistance at all.
You'll find full instructions on the Norman Butkus website where he's provided a downloadable .pdf manual for your camera for free download.
Hopefully this has solved your problem; if so all I ask in return is for you to rate my answer. If it hasn't, then please add a comment and I'll try to offer other solutions to your problem.
1helpful
I loaded the film but display window shows a flashing zero
Go ahead and try anyway. A ruined film is far cheaper than a useless camera or a professional repair. In any case, if the film hasn't loaded properly it will only be the first short length of film which is ruined. As this is a newly loaded film you haven't any risk of losing any undeveloped photos.
Auto spooling film systems are great when they work, but sometimes are a real pain and some cameras seem really picky about having a film leader of precisely the right length. See if you can engage the the film onto the spool manually.
Film loading problem Minolta Maxxum 430SI RZ
not solution, but a suggestion, something to look for/try.
i think it is trying to tighten it and take up the slack in the spool. there might be little red dots or something like that on the inside when you open it up. you are supposed to have the film go to a certain spot before you close it. normally, the film is sticking out the right length, but you might have to pull it out extra first. you might also have to tuck the end of the film behind a roller or in front of a roller before you close it. look for really tiny diagrams inside the camera, or maybe just tiny arrows indicating which way the film is supposed to wind. good luck with your class!
I cant seem to load film in my camera . it winds it back up as soon as i close it or try to take pictures
It's still in auto-rewind mode. Depending on the model, do a manual rewind with no film in the camera to reset the internal counter. Then load film and try it. Please leave feedback if this helps.
Jul 26, 2008 • Cameras
Fuji 35mm Camera (Model DL-400)
Dawn
remove the battery and check that it is good. replace battery and open back door, close the door and it should run the motor / transport. if so, load film up to the drive sprocket being sure film will catch on the sprocket.
or move the latch holding back cover, and open the door fully. check the pressure plate on the door, gently pull the plate up a little to increase pressure on the film. bring the holding lever out toward the latch and close the door to lock the lever back to position.
2answers
N75 will not load film
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
Hope this helps
Top Nikon Photography Experts
Tony Parsons
Tony Parsons
Pallikonda Nisha
Level 1 Expert
Are you a Nikon Photography Expert? Answer questions, earn points and help others
