Question about Frigidaire Kitchen Ranges
What does F16 mean on a frigidaire gas professional range?
    Top Expert:
  • Frigidaire Master
  • 64,245 Answers
Google it
Posted on Oct 30, 2016
SOURCE:
FRIGIDAIRE ERROR F16
Disconnect power, wait 30 seconds and reapply power. If fault returns upon power-up, replace EOC. Electronic oven control or get a new oven.Goodluck)
Jul 20, 2016 | Frigidaire Kitchen Ranges
I have a new Frigidaire Professional gas range. I am trying to convert it to propane and I do not know how to convert the oven burner.
need to get a conversion kit if not already set up for one the pressure is different between natural gas and lp/propane gas set ups
Aug 29, 2015 | Frigidaire Kitchen Ranges
What does f31 error mean on fregidare gas range
Good Morning friend, thank you for your inquiry!
From what you have described your Frigidaire range is displaying an "F31" error code. An "F31" stands for a shorted probe connection. This could be an issue with your RTD (Resistance Temperature Detector), EOC (Electronic Oven Control), or wiring harness. I would recommend performing a reset on your range to help clear out any false error codes. In order to reset your range you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue and you continue to receive the error code you may need to have a professional out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Mar 30, 2015 | Frigidaire Gallery 30" Self-Cleaning...
Have beeping f68 how do we stop the beeping ????
I appreciate your inquiry, friend!
I understand that your Frigidaire range is displaying an "F68" and beeping. I would recommend performing a reset and you can do that by flipping the household circuit breaker off for roughly ten minutes, which should clear out any miscommunications within your range. If your range continues to display "F68" that could be a high voltage condition. This means that you may have an issue with the voltage coming into your range or your control panel. This is not a simple fix. I would highly suggest consulting with a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 01, 2015 | Ovens
Frigidaire oven FGB24L2ASA. Igniter glows red, gas turns on, but does not light.
I appreciate your inquiry, K Ogle!
From what you have described about your Frigidaire range the igniter glows red and the gas turns on but it will not light. It sounds like it could be a faulty burner or igniter and I would recommend having a professional come out to properly assess your range. This does not sound like a simple DIY job. Good luck. -Matt
Feb 17, 2015 | Frigidaire Kitchen Ranges
Frigidaire gallery gas range temperature display lights are very dim
Hello Peter Robinson - If the display LED's are dimmed on the range but it is working, then it sounds like more than likely the EOC (electronic oven control) or wiring failure will need replacing. I personally recommend contacting a professional for an accurate diagnosis and to assist with the repairs. You can often locate a qualified provider by visiting the manufacturer website.
Mar 04, 2013 | Frigidaire Gallery 30" Self-Cleaning...
I have a frigidaire gallery range that is slow to ignite when the oven is turned on and when it does ignite it"s slow in reaching the set temperature. Also there is a smell of gas.
You would definitely want to seek out a professional technician to diagnose the unit. Gas units are very dangerous if you are not use to working on them. You could have a slow gas connection or flow, a faulty valve, or bad ignition. All would absolutely need a professional to diagnose and repair, this is not a typical DIY job.
Dec 26, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F10 error code on Model # FEFL79GCA Frigidaire Stove
Hello - Typically error code F10 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 24, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire gas range makes loud whirring sound when oven is set above 250
You don't give a lot of info here (like if the range was converted from natural to LP, or if the burners are OK, or if it is a self clean model and how the broil works, etc) and I can't guess all that, especially because a lot of people post under whatever model pops up when they enter a key word while posting a problem, but,..........
Any range that was professionally installed should have been tested for proper burner and oven operation by the installer before they left. Call the installer back and let them know you are not satisfied.
Nov 02, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Kitchen Ranges Logo
597 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
