I have the original owners manual so dont need a link thanks
SOURCE: Disassembling the gearbox on Kenwood mixer A707
If the belt wheel is pressed onto a spindle, you need a gear puller. Do you have any pictures of this? I am trying to visualize the problem.
SOURCE: beater doesn't turn
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
SOURCE: KitchenAid K5sswh mixer after replacing plastic gear-no power
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Testimonial: "Dear hslincoln,Thank you for your very helpful link to diagram that showed exactly what to. It was fixed within 3 minutes"
SOURCE: I need diagram of gearbox for Hobart d330 mixer
Parts manuals are available for viewing and free download at www.hobartservice.com
Testimonial: "I know,ust can't find them. If you could explain to me how, I would appreciate it"
SOURCE: can't remove beater kmix from machine. it's stuck!kenwood
Here's how to fix the stuck implement problem:
The implements
each have adjustable heights. to adjust the height you need to loosen
the bolt at the top with a 14mm spanner. If the bolt was loose when it
was being used then it can get too short and not leave enough clearance
between the bolt and the machine in order to push up and turn to release
the implement. If this happens take the open ended spanner, grasp the
implement and rotate the spanner clockwise (when looking up at the
machine from below. Once the nut is loose rotate the implement until
there is enough clearance to remove it normally.
