As you have not mentioned the brand and the model number i assume you are using canon ir series
how to counter clear In Canon Ir 5870 5800 photocopier
SOURCE: toshiba 1360
Did you replace the cleanerblade?
Power off the machine, switch on while pressing 0 & 8, enter 200, then press the start button, the machine will run for about three minutes to adjust the Toner sensor. The machine will stop, press the interupt button to save the setting, switch off and then on.
If the older techies is reading this, please help to confirm.
SOURCE: Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
SOURCE: I have a Okidata b4600.
Hi Please check this link for the resolution to your toner sensor error:- http://my.okidata.com/oki-faq.nsf/FAQCentral/C384D8F74A91CF6E8525765E0065F636?OpenDocument For drum reset:- Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Sir, Mam, Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade the reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything unit the F8 is run. Or you start over again with new developer and new drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Have you had the developer and drum replaced or does the screen say Replace PC Drum? . Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE AVACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you start over with new developer and new drum
