SOURCE: bobbin case on brother sewing machine
Well, from the picture I see that your bobbin is a front load as opposed to a top load.. if you tilt the front panel down, you will see where the bobbin and casing goes. Put the bobbin in the casing with the thread pulling from the right hand side of the casing making sure the thread in guided into the small **** on the top edge of the casing.. On the back of the casing the will be a small tab. Pull that away from the casing and enter the casing in to the opening for the bobbin. It should snap into place when you release the little tab.
SOURCE: I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE
Sounds like either the bobbin case tension is too light or is not in the tension at all.
Consult your manual for how to place the thread in the tension and retry. Increase the bobbin case tension if necessary.
The top tension may be set too high.
SOURCE: My needle broke on my Brothers LS-2125 sewing
You can use any brand of needle. The flat part of the needle faces back. Undo the little screw that holds the needle slightly until you can remove the old one. Put the new one in all the way up as far as it will go (flat to the back) and tighten the screw. I would recommend a size 14 ballpoint for regular sewing
SOURCE: My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
SOURCE: I have a brother ls-2125 sewing machine. the upper
Timing
Thread
Hi Crystal Luttrell, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Did you take it apart or was it apart when you got it? I can't tell from the picture but it appears that the metal is rough? I can't tell for sure. If the metal is rough, you need to polish it first in order for it to work once you put it back together. I found that once I had a cell phone, I took a picture before I took it apart! Saved me some time later! Can't tell you how many times I had trouble putting a tension back together. If you send a closer up so that I can see the piece you are working with for sure. From here it looks like you might either be missing a part or have a broken part. Thanks!
