Electrical Supplies Logo
Chris Gates Posted on Oct 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black max generator hard start backfires ,if it does start doesn't stay running
magna buff
Level 3:
  • Master 3,828 Answers
  • Posted on Oct 28, 2016
magna buff
Master
Level 3:
Answers
3828
Questions
0
Helped
1113615
Points
21593
Will be motor issues
start with carby and adustments
spark issues
governor
valve clearance
Black Max Generator Parts mastertoolrepair com
2 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on May 02, 2010
SOURCE: black max 7kw generator high voltage output
Those voltage readings MAY be normal.
The AC waveform may cause your meter to read inaccurately. You would need to use a TRUE RMS meter to accurately read the voltage.
The siple meters actually read the AVERAGE voltage and then are calibrated to mulltiply it by the "form factor" for a sine wave. OFTEN these generators don't produce a clean sine wave. A square-ish wave will read higher on the garden variety meters.
Compare the brightness of a lamp comparing to when run on your utility.
The frequency depends on engine speed ... yours is running a bit fast...check it under at least half load and if off, adjust the govenor slightly.
Testimonial: "Still working on the problem but tips were a real help."
Chuck Graybill
  • 104 Answers
  • Posted on Jan 26, 2015
SOURCE: Brand new gx390 Black Max
If you can access throttle linkage to the carburetor, slow the engine speed to idle before turning off. As mentioned in the previous answer ... turning off the fuel valve and letting it run dry is good if you are not planning to use it real soon.
Honda Black Max 8450 Generator. I need a picture of the carburetor please.
Question edited for clarity, add maker, put stuff in correct order and spell 'carburetor' correctly.
There is a pretty picture of one here.
https://www.google.com/search?q=black+max+8450+generator+carburetor
2answers
I have a 7500 w Black Max generator not producing power and it only has 6.2 hours on it.
This small amount is used to create an electromagnet. As the engine begins to turn this electromagnet, moving its electric field, through the stator windings, your generator will produce more power. However, if residual magnetism is lost, your generator will produce no power at startup.
Mar 15, 2022 • Garden
3answers
Plug fouls out turns black and starts to backfire
What does the oil look and smell like? Also what conditions is it been ran in lately, and what fuel are you running?
2answers
Why does the motor rpm fluctuate while running?
replace spring apparently it lost its tension for it to stay open you may also have a dirty carburetor if it does not run smoothly with the choke wide open have it serviced or clean it yourself if your mechanically inclined it should be a piece of cake.
1helpful
3answers
Brand new gx390 Black Max generator backfires when shut down. Might this be plug gap problem?
7helpful
4answers
Where can I find an owners manual for a Black Max 8125/ Honda GX390 OHV generator? I searched Honda's site but not there, no black max site. My lawn guy pulled a wire off and I need to see where it is...
low oil sensor will not cause the motor not starting.
most likely is th ground wire.
you can try to attach that wire to any surface and try to start it. of it start, then you have to dis-assemble the head and find out where the wire should be attached.
if not, the wire is attached to a hot side. either way you have to dis-assemble the head.
http://www.honda-engines.com/engines_owners_manuals/ownersmanuals/gx390.htm
here is the site for the manual.
Generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Top Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
